How much torque?
Posted: Thu Apr 28, 2022 12:58 pm
by WayneJ
How much torque for a wrist pin bolt, and how much for rod castle nuts?
Thanks!
Re: How much torque?
Posted: Fri Apr 29, 2022 12:47 am
Perhaps more important than the torque applied to the wrist pin bolts is how that torque is applied. The piston/rod assembly needs to be held by the wrist pin when torquing the pin bolt. I have two dummy spiggots which go in each end of the wrist pin, and then the whole is held in a vice while the bolt is tightened. Otherwise you run the real risk of twisting the rod if it is held while the bolt is tightened.
Hope this helps.
Posted: Fri Apr 29, 2022 3:33 am
by Kerry
Some who like to use a torque value say 30lbs. I still do it Henry's way of by feel, Also as Allan has posted, hold by wrist pin when tightening the bolt, the pin is hollow so slide onto a phillips screw driver in a vice, also remember that the wrist pin bolt faces the cam shaft when assembling engine.
Posted: Fri Apr 29, 2022 3:45 am
I use a piece of rod held in the vice and go by feel also, using an original Ford wrench.
Adding: Forgot because I have not used it yet, I have a piston vice.
Posted: Fri Apr 29, 2022 4:23 am
by ABoer
Posted: Fri Apr 29, 2022 5:56 am
Just like mine Toon. They hold the pin tightly with no slop at all.
Posted: Fri Apr 29, 2022 10:50 am
I also use a piston vice & a rod through the pin. Rod bolt nuts I also hand tighten by feel - I assume if one's intent on utilizing a torque wrench, I believe a grade 5 bolt is 6-8 lbs. per 1/8" - Model T rod bolts are 3/8" so close to 24 foot lbs.
