Dated 1912 Hogshead
Topic author - Posts: 118
- First Name: Rich
- Last Name: Chillingworth
- * REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
- MTFCA Number: 30527
- MTFCI Number: 23207
Dated 1912 Hogshead
Below is a transmission hogshead I bought at Tulare this year. It’s a 1911-12 style where the clutch release forks are attached to the high speed clutch shaft using Woodruff keys and clamps. The cover was complete with DB pedals and all the other internals when I bought it, but have since removed them.
What I find interesting is the casting date, located above the access door opening. Not only does it have a date, 6-16-12, but also says DAY. Does this mean there are other dated hogsheads that say NIGHT? Curious minds...
Rich C.-
- First Name: Rich
Re: Dated 1912 Hogshead
Being curious minded paid off! My original post, above, showed a 1912 hogshead where part of the date said DAY and my whimsical question was does this mean there are contemporary covers that say NIGHT? It turns out that the answer is yes!
Rich C.-
the difference is as clear as night and
NH Full Flow Float Valves
- First Name: Rich
- Last Name: Bingham
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Pretty cool. I have yet to see one hogshead with a casting date!
- First Name: Gene
- Last Name: Carrothers
- MTFCA Number: 22905
- MTFCI Number: 23068
I have a HH with no gussets so I assumed it is a '12 but I'll have to take a close look! Thanks for posting. Where did you find the second one that was night?
1912 Torpedo Roadster
- First Name: Rich
The NIGHT hogshead is not mine, but I discovered it in this thread: https://www.mtfca.com/discus/messages/3 ... 84103.html
Rich C.
Rich C.
- First Name: Warwick
- Last Name: Landy
- * REQUIRED* Type and Year of Model Ts owned: 1916 LHD USA Touring 1916 RHD Canadian Touring 1916 Pickup
All the time learning. I have never seen this before on any hogshead. Of course, I am generally only looking at RHD stuff , but will look closer now to see if the same markings are on the Aussie/Canadian right hand drive versions.
