Contact Between Individual Leafs in a Spring
Posted: Sun May 01, 2022 5:05 pm
What I am going to try to show you, surprised me. Apparently, the "rubbing" contact area between individual leafs in a spring occurs only near the end of the leaf.
The first photo shows seven of the eight leafs of the rear spring for my 1927 coupe. The next two photos are of the second and third leafs from the top.
The second photo shows the right ends of the pair. The third is a close-up. In the upper leaf, you can see the "rubbing" contact area. The yellow piece of tape shows the " length of the area" where the Ford script is located on the back side of the other leaf.
The fourth photo shows the back side. Note how close the script is to the "rubbing" area and that there is no indication of any "rubbing" over the script area. I looks like the "rubbing" occurred over about 2.5 inches. I knew that "rubbing" would occur near the leaf ends, but I thought there would be indications of "rubbing" at other areas along the leaf.
Someone told me that lubrication is only needed over the end 4 inches of each leaf. Maybe he had a point!
I followed Jim Patrick's recommendation to grind the bottom corners at the end of the leaf.
I will have some additional photos of another leaf and some comments in follow-up post.
