Air Friction carburetor instructions and other literature
Posted: Tue Apr 09, 2019 11:00 pm
by dobro1956
I just acquired several air friction carburetor pieces of literature. Here are some scans of them ..
Re: Air Friction carburetor instructions and other literature
Posted: Tue Apr 09, 2019 11:01 pm
by dobro1956
Posted: Tue Apr 09, 2019 11:02 pm
by dobro1956
Posted: Tue Apr 09, 2019 11:03 pm
by dobro1956
Posted: Thu Apr 11, 2019 12:42 am
by JWalters
Good stuff Donnie! Thanks for sharing this info with us!
Jason Walters
Posted: Fri Apr 12, 2019 10:56 am
by Eric Hylen
Thanks, for posting this info. I’ve got an Air Friction carb on the shelf that I’ve been meaning to try out. Having the proper instructions will make setting it up easier.
Posted: Fri Apr 12, 2019 11:56 pm
by Corey Walker
I bought one of those to find out what was inside. It seems to run ok but I didn’t run it for enough to check the mileage claims. The venturi slides up and down, I suppose it acts as an air valve like the flapper or balls in a Kingston.
Posted: Sat Apr 13, 2019 12:33 pm
by dobro1956
Air Friction carbs are fairly common, but other than ads, I have seen very little info or items pertaining to the carbs. A few years ago I did find a watch fob, and a hat/lapel pin. Im not sure if I ever posted a photo of the watch fob and pin. So Ill post them here, just in case .....
