Touring roof windshield clamps
johnernst
Last Name: Ernst
* REQUIRED* Type and Year of Model Ts owned: 1922 Canadian Touring
Post by johnernst » Sun May 08, 2022 2:30 pm
Does anyone have any insight into the difference between these 2 windshield clamps ? The right one came with my 1922 Touring and the left one came with the 1923 roof irons i just found. The right ones have a smaller diameter and dont fit on the windshield posts I now have.
John
MTFCA Number: 4838
MTFCI Number: 115
Re: Touring roof windshield clamps
Post by DanTreace » Sun May 08, 2022 2:38 pm
The bracket on the right isn't Ford. Some other auto.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sun May 08, 2022 2:43 pm
The left is correct for one man tops 23-27. The right, I have not seen before, but in researching better than stock options for top tie downs on 17-22 ,I suspect its part or an after market non strap method. There would be a rod to pick up the lower W/S hinge To meet that neat clamp attached to the front bow as seen in model T accessory adds.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sun May 08, 2022 7:19 pm
There are two different styles of thumb screws too, early and late. The early ones look like the example on the right.
MTFCA Number: 1219
Post by Rich Eagle » Sun May 08, 2022 9:11 pm
This shows the difference in the clamp screws.
http://www.mtfca.com/discus/messages/331880/334842.jpg
By Dan Treace, Jan. 12, 2013
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon May 09, 2022 10:52 am
The photo above has it backwards.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Mon May 09, 2022 12:18 pm
My '25 Touring has the one on the left, both in the OP's photo, and in Rich Eagle's link.
First Name: Jeff
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Tue May 10, 2022 7:16 am
John, I have never seen one like you show in the right of your picture, do not think it is Ford.
johnernst
Last Name: Ernst
Post by johnernst » Sat May 14, 2022 11:00 pm
Once again thanks for all the information. That helps a lot.
John
Lawrence
First Name: Chris
Last Name: Lawrence
* REQUIRED* Type and Year of Model Ts owned: 1926 fordor sedan,1927 fordor sedan. 1922 tourer, 1913 torpedo roadster pickup
Board Member Since: 2014
Post by Lawrence » Sun May 15, 2022 7:10 pm
My Canadian 1922 tourer has them, all Canadian 20 to 23 t's have them
