Exhaust rings for different car
Posted: Sun May 22, 2022 5:05 pm
by Linus Tremaine
I have a 1921 studebaker and it uses the spring steel rings between the block and the manifolds. I found that some of mine were missing and I wonder if there is a general source that makes these for model T and other cars. Does anyone know where I might find some?
Re: Exhaust rings for different car
Posted: Sun May 22, 2022 5:14 pm
The rings are not spring steel. They are a strip of soft sheet metal of the proper length & width that when bent into a circle fit motor & manifold recesses. The better rings are made of tubing machined to the proper dimensions. You can make your own of either type easily yourself. If not, a machine shop could do the job cutting some tubing rings.
Posted: Sun May 22, 2022 5:28 pm
by Rich Eagle
I just cut them from sheet. John is right. If you had the right size tubing that would be better.
Posted: Sun May 22, 2022 6:16 pm
by Linus Tremaine
Thanks guys. I will make them.
Posted: Sun May 22, 2022 6:56 pm
by Henry K. Lee
Or make them from a short piece of exhaust tubing/pipe.
Posted: Sun May 22, 2022 7:44 pm
Continuous rings cut from exhaust pipe tubing are better. Thew will not deform like the strip type nor give grief when fitting the manifold. Also, if you do not have a source for gasket rings, they can be cut from any exhaust gasket material. When I built the header for my speedster, I cut six rings, already formed, from a gasket to suit a modern 6 cylinder car. Just see your parts house to find one for your purposes.
Hope this helps.
Posted: Sun May 22, 2022 7:53 pm
by Craig Leach
Are the rings larger maybe model A will fit.
Craig.
Posted: Mon May 23, 2022 12:59 pm
by Dan McEachern
Restoration Supply has the copper crush rings in various sizes- see page 45 of their catalog.
https://restorationstuff.com/
