Coil Shim Sets
Posted: Thu May 26, 2022 1:37 pm
by J1MGOLDEN
Today, I got a set of door and window shim sets at Lowes for about $6.00 and they make excellent coil shims.
With them still sealed tight with plastic wrap, I cut the pack in two at the middle with a miter saw.
Then cut each section in two off center, so I had 1 inch and 1 1/2 inch wedges.
Then made the ends slightly smoother on my belt sander, not that they needed this cleanup.
The largest pieces on one end were saved for clamping other wood pieces that I didn't want marred.
Coil Shim Set.jpg (65.09 KiB) Viewed 2190 times
Re: Coil Shim Sets
Posted: Thu May 26, 2022 1:54 pm
by Russ T Fender
i use the small free formica samples from Lowes and Home Depot as shims. They work great. I also use the large samples for leveling heavy machinery.
Re: Coil Shim Sets
Posted: Thu May 26, 2022 2:46 pm
by Dan Hatch
That is why they make popsicles. The sticks work good.
Re: Coil Shim Sets
Posted: Thu May 26, 2022 5:08 pm
by TWrenn
Been using those inexpensive wood shims since I started the hobby in 2012. Just slide them in til you get the desired tightness and chop off the excess!
Re: Coil Shim Sets
Posted: Thu May 26, 2022 7:27 pm
by Allan
Where on a coil is a wooden shim needed?
Re: Coil Shim Sets
Posted: Thu May 26, 2022 7:59 pm
by Ron Patterson
If you properly rebuild your coilbox; shims are not required.
It is just another half-vast things people do to model T's. :)
Ron Patterson
Re: Coil Shim Sets
Posted: Thu May 26, 2022 8:22 pm
by J1MGOLDEN
Then too, if you put your rebuilt coil on the belt sander to smooth and clean a warped case, it fits in the box easier, but sometimes a little too loose.
Re: Coil Shim Sets
Posted: Thu May 26, 2022 8:25 pm
by J1MGOLDEN
Allan, the shim pushes the individual coil boxes closer to the contacts for a better electrical connection.
Again, not needed if the contacts are properly bent away from the wood side.
Re: Coil Shim Sets
Posted: Fri May 27, 2022 2:17 am
by Allan
Now I understand. It's a colibox shim, not a coil shim. Proper arches in the coil box contacts will do the same. The only shim I have ever used on a coil is a couple of washers under the contact posts to compensate for crushed wood on the top, so I couldn't get my head around wooden shims for that application.
