Radiator aprons.
Posted: Thu Jun 02, 2022 9:02 pm
A recent post detailed some problems fitting a late model apron to an improved car.
My 1925 roadster needs an apron like these, but I have to use an earlier narrow one to clear the accessory shock absorbers.
The khaki one I restored for the roadster. The grey one is for the 26-7 models with the extra hole for the screw below the crank handle. Dimensoinally, they are identical, except that there is mo evidence that the grey one ever had the sleeve around the crank handle hole.
The black one I suspect is new old stock. There is no sign of it ever being bolted on. There is no wear in the mounting stud holes, and no flogging of the handle sleeve flange. I believe this is the correct one for my 25 roadster, as it has the side 'war's which are sandwiched between the frame and fender mounts, just like the one on Henrietta.
From the photo you can see that this apron is narrower, top to bottom, than the other two, by 15mm. Does this reflect the change in arch of the front frame cross member on the lowered 26 -7 frames?
