Bridgeport 2 cyl tire pump
Posted: Fri Jun 03, 2022 10:00 pm
I finally decided to bite the bullet and pick up a 2 cylinder pump without visible dings and restore it completely.
Has been more frustrating than a T to get into, but finally there. Someone rebuilt this one back when I was a baby I think and did a lot of shade tree fixes so thought to just copy would be fruitless.
A few questions...
1 - Is there any place to find a seal kit? I've seen videos of making plunger seals out of layers of cork using the tube as the die, I know that Restoration Supply sells seal cups of about 8 different diameters, was just wondering if someone has figured it out before and could point me in the right direction on what to do. .
2 - The small cylinder stem packing box was filled with some sort of coned rubber faucet washer with black stuffing box twine sandwiched with a coned spring washer. I have serious reservations about trying that trick again. Any recommendations?
3- What is the purpose of the hex head screw in the top of the large cylinder? Not sure it is there to adjust anything but it does have a machined dog point on it?
4- Is there a check valve somewhere or do you just pump fast?
I'll have other questions as I go along but these are the obvious for now.
Thanks in advance.
A few questions...
Thanks in advance.
