Generator testing out of car.
Posted: Sun Jun 05, 2022 2:13 pm
by Been Here Before
Any suggestions, shared knowledge, tips for testing a generator out of the car?
Re: Generator testing out of car.
Posted: Sun Jun 05, 2022 2:44 pm
Gen test stand. See T1 manual. The gen needs to be made to run hooked up to an ammeter. Checking on your motor works. Does it produce voltage @ the terminal? The manual will give other tests by having it powered to motor with & without the 3rd brush down. A good battery or high amp battery charger for power.
Posted: Sun Jun 05, 2022 2:57 pm
There is some good testing information in the MTFCA electrical manual. When working on a Model T the information is readily available about how to do it. The manuals are really helpful.
Posted: Sun Jun 05, 2022 8:07 pm
by JohnH
Connecting a battery to it and running it as a motor is a simple go/no go test, which will give some idea about the condition of the windings, brushes, and bearings. To test it properly, you really need to apply a rotational force at an appropriate speed, and feed it into battery or suitable load resistor in series with an ammeter. In other words, duplicate the in car set up.
Posted: Sun Jun 05, 2022 9:35 pm
by Dan Hatch
Here is what I use.
Posted: Sun Jun 05, 2022 10:05 pm
Is your generator not charging or it’s not working correctly or?
Posted: Mon Jun 06, 2022 5:23 am
by ABoer
Here is what I use .
Toon
Posted: Mon Jun 06, 2022 6:47 am
by Brent Mize
I use an Allen spin tester.
It does a great job and it’s compact.
Posted: Mon Jun 06, 2022 8:33 am
by Plankhill
I made this one out of a generator bracket, an old timing gear, jack shaft, and old appliance motor.
Posted: Mon Jun 06, 2022 1:46 pm
Brendan, in an age where we give prizes for just showing up, I think you deserve a STATUE for creativity. I love this on several different levels! :D
