Is This a Good Substitute?...
Posted: Fri Jun 10, 2022 9:43 am
by George House
I see by an oil pool underneath the crankcase oil drain that my often used crush washer failed. Cannot find a replacement in small town hardware and auto parts stores but did find neoprene washer that’s a tight fit on the oil drain plug. Would this be a long term fix ?
Re: Is This a Good Substitute?...
Posted: Fri Jun 10, 2022 10:04 am
by Rich Eagle
Almost any seal material will work. I often used a 1/16" or thicker paper gasket. It's just oil.
Posted: Fri Jun 10, 2022 10:08 am
by mtntee20
George,
Did you look for a copper washer? If you are unable to find a proper fit, make your own out of copper sheet. The only critical dimension is the inside diameter hole so it fits properly on the drain plug.
Good Luck,
Terry
Posted: Fri Jun 10, 2022 10:14 am
Copper is the only way to go. I think I've bought those from Lang's.
Posted: Fri Jun 10, 2022 10:19 am
by George House
Thanks to all. Good advice. I’ll make a washer out of thick gasket material and order a few next time I need a shipment from a vendor...🙏
Posted: Fri Jun 10, 2022 10:39 am
by John Heaman
I use string.
Posted: Fri Jun 10, 2022 12:14 pm
by TWrenn
Me too and yes Langs has them. Or at least they used to. Nowadays my first question to any vendor is if they even HAVE it in stock!
Posted: Fri Jun 10, 2022 12:49 pm
I am a Stat-O-Seal convert
I use them on pan screws, transmission door, and drain plugs...even modified the OD on one to seal the low-band adjuster. For the first time since I entered the hobby, I have cars which will rarely drip a drop of oil. Seriously...I can't recommend these things enough
they are moulded-in-place o'rings which have an aluminum washer which limits the crush on the oring to the exact designed compression...they simply work (and they are reusable, too)
https://www.pegasusautoracing.com/produ ... oduct=3245
Posted: Fri Jun 10, 2022 1:08 pm
by George House
Very good Scott. Typically great advice from you. And I use feed sack string too, John, with 4-5 wraps around the bolts of the bottom pan inspection cover. 😁🇺🇦
Posted: Fri Jun 10, 2022 1:13 pm
Ace hardware has copper washers.
Posted: Fri Jun 10, 2022 2:07 pm
by George House
John, Ace Hardware might advertise they sell copper washers but Ace Hardware in Lockhart doesn’t sell them. That’s where I bought neoprene washers of the right I.D.
Posted: Fri Jun 10, 2022 4:38 pm
by Wayne Sheldon
George,
Good Luck,
Terry
Years ago, I had a pan that had an about an inch square piece of copper sheet with a tight fitting hole in the center to fit the plug. the corners were wrinkled and bent, but otherwise sticking out. It was on my engine when I got it, and on the engine for years after I got it running! It was a bit awkward to remove and replace as only one pair of hex sides was reachable by wrench, but not that difficult. I left it and worked with it for years as part of the car's history.
Worked just fine.
Posted: Sat Jun 11, 2022 9:02 am
by RGould1910
I've used a leather washer ro cure a stubborn leak.
Posted: Sat Jun 11, 2022 9:47 am
by babychadwick
RTV works as well. I recommend one of the big pump tubes to maximize loss though.
Posted: Sun Jun 12, 2022 11:21 pm
by Dennis_Brown
HARBOR FREIGHT sels a box of multiple various sized copper washers. Lots of places you can use them. They used to be 10 to 11 dollars.
