Need spark plug nut
Posted: Tue Jun 14, 2022 6:44 pm
by Emeraude
I lost the small nut that holds the plug wire on the plug.. I tried a 6/32 nut but was the wrong thread. Is there a nut that can be gotten without buying a plug?
Re: Need spark plug nut
Posted: Tue Jun 14, 2022 7:04 pm
by Inthegarage
Home Depot carries the top nut for the spark plugs I don’t remember the size of hand sorry but someone will chime it
Posted: Tue Jun 14, 2022 7:10 pm
In the back of my infertal mind, I recall the same issue from many years ago. The plug top thread was metric.
The solution was to get brass thumb nuts & re tap to the plug's metric thread.
Posted: Tue Jun 14, 2022 7:13 pm
by jsaylor
Autolite and MotorCraft use 7mm. Champions ate 8/32. Langs has the Knurled type in both sizes.
Posted: Tue Jun 14, 2022 7:56 pm
Ace hardware has a good selection of various brass nuts.
Posted: Tue Jun 14, 2022 9:39 pm
by Bryce S.
I've got a good selection of nuts that was in a box. Let me take a look tomorrow and see what I have. If I find any I'll send what I have. Don't worry about the shipping. I have some stamps I need to burn up.
Bryce
Posted: Tue Jun 14, 2022 9:43 pm
there are a number of different threads on different "T" plugs, and a number of different versions of nuts, PLUS there are some nuts advertised as being correct and while they fit, they are far from correct!
show the plug, and the nut that fits (that is missing) and you'll get more certain help
Posted: Tue Jun 14, 2022 10:08 pm
by Rich Eagle
Many of my Champion brass top as well as the new ribbed plugs are #8-32 thd. Some of the Champion X plugs are smaller, #6-40 (I revise this to #5-40 per Steve's post below). I have some 14mm plugs with #8-36 thds.
What make are your plugs?
Posted: Tue Jun 14, 2022 10:44 pm
by Art M
If you were closer, I would tap the thread on another nut you the thread size you need. Like previously said there is no std for this application.
Art Mirtes
Posted: Tue Jun 14, 2022 11:57 pm
Early Champion X plugs take a 5-40 nut. Later Champion X (brass hat) are 8-32. The latter are easy to find with a google search. 5-40 plug nuts are made of unobtainium, so I bought slightly smaller ones and ran a 5-40 tap through them. I haven't researched thread sizes of modern plugs.
Posted: Wed Jun 15, 2022 11:41 am
by Rich Eagle
Thanks for that Steve. I rechecked 6 of them and they are #5s rather than # 6 as I had stated. You may want to recheck yours. Mine are all 40 threads per inch. Still, they are "made of unobtainium". Standard # 5 taps are 40 tpi and 44 tpi.
Posted: Wed Jun 15, 2022 11:49 am
these folks have helped me out on some of the more unusual stuff: https://drillsandcutters.com/search?q=5-40+tap
Posted: Wed Jun 15, 2022 11:53 am
by Rich Eagle
Thanks Scott, I meant the #5 knurled nuts are made from "made of unobtainium".
Sorry for not being clear.
Posted: Wed Jun 15, 2022 11:54 am
I should have realized that :oops:
Posted: Wed Jun 15, 2022 11:56 am
Do you have some idea as to approximately where it was lost? My point in asking, is that many of us have "heard of other people" who have dropped the nut into an open spark plug hole. If so, it's gotta come out...
Posted: Wed Jun 15, 2022 12:09 pm
I know someone who has done that. Since its brass, I tried to vacuum it out without success (wet/dry vac with no bag). Going to pull the head.
Posted: Wed Jun 15, 2022 12:14 pm
OOooops! My memory slipped a cog. Rich is right. The early plugs take a 5-40 nut. Corrections made.
Posted: Wed Jun 15, 2022 12:37 pm
by Rich Eagle
If I may, here are 2 cuts from the Lang's site. They do offer the #5-40 as well as the #8-32 if these are still available.
They seem to be made out of Brass rather than unobtanium as we had thought. :D
Posted: Wed Jun 15, 2022 11:21 pm
Mein gott! $6.24 a nut! I believe in supporting our parts dealers, but I'll spend the money on things I can't get elsewhere, especially when elsewhere is a fraction of the price (71¢ on Amazon). I love Lang's, but not for plug nuts. :)
Posted: Thu Jun 16, 2022 2:10 pm
by Rich Eagle
I feel your pain Steve. $24.95 hurts me more than $6.24 a nut. :D I might make some if I needed but I'm not using those plugs in anything right now.
Still, I was delighted to see they weren't impossible to find. I wouldn't make them for less money to sell.
It's been a good thread.
Posted: Sun Jun 19, 2022 6:39 pm
by TMiller6
This is how I learned to retrieve stuff like terminal nuts from cylinders.
https://gus-stories.org/august_1967.htm
Posted: Sun Jun 19, 2022 9:07 pm
Not sure what you found on AMAZON but not all knurled nuts are alike. Lang's is selling original style nuts for those seeking originality.
Orig n.png (102.95 KiB) Viewed 3886 times
Orig 5-40.png (90.96 KiB) Viewed 3886 times
For the rest who are looking just for a functional solution and are content function over form there are other choices.
I found this seller on ebay - has several items (ignition wires etc ) for hit-mis engines that could be used on a T Considering free shipping and a close knurl design plus one spare
https://www.ebay.com/sch/i.html?_ssn=zk ... c=1&_pgn=1
Posted: Sun Jun 19, 2022 10:49 pm
I bought 4-40 nuts and ran a 5-40 tap through them. I don't imagine they're an exact reproduction of the originals, but I expect a small fraction of 1% of the people who see them will know that. As the old saying goes, close enough for gummint work.
