Brass cleaner suggestions?
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1915 Runabout
MTFCA Number: 50256
Post by NealW » Tue Jun 14, 2022 7:21 pm
I've got a lot of brass to clean on the 11T that I am restoring. Some of the brass is heavily corroded. I used Brasso on the 15 runabout that I restored. It works okay, but I was wondering if there is a better product for cleaning and polishing brass that someone can suggest.
Thanks,
Neal
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
MTFCA Number: 21848
MTFCI Number: 22173
Re: Brass cleaner suggestions?
Post by rickd » Tue Jun 14, 2022 7:35 pm
I like Blue Magic metal polish. I get it at O'Reillys auto parts stores in my area.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue Jun 14, 2022 7:38 pm
Wenol is some of the best polish/cleaner I've used.
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910, two1911, 1913 Tourings
MTFCA Number: 52262
Post by Pat Branigan Wisc » Tue Jun 14, 2022 8:02 pm
My brass polisher always liked Mothers before She went on strike. It will be 40 years this year so I better let the strike continue!
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue Jun 14, 2022 8:03 pm
After you clean your brass pieces use Cape Cod polishing cloths. You will be amazed how the polishing cloths will polish your brass after you’ve used them. Also work great polishing the headlight reflectors.
Post by TRDxB2 » Tue Jun 14, 2022 8:38 pm
I differentiate between removing tarnish versus polishing
If the item is tarnished brown - polish will take forever.
There are many variations of using a mixture of white vinegar & salt + other ingredients to remove the heavy tarnish easily https://www.countryliving.com/home-main ... ean-brass/
For maintenance & polishing there are two products that I use Flitz (less expensive) & Simichrome (best)
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Tue Jun 14, 2022 8:44 pm
Some polished brass was sprayed with a coat of lacquer to preserve the shine, but, overtime, this lacquer dulls and darkens. Until this old lacquer is removed, any polishing you do will be to the surface of the lacquer until you polish through it to the underlying brass, at which time the brass will begin to shine. This is very time consuming. Better to remove the lacquer with lacquer thinner before attempting to polish the brass. Jim Patrick
PS. I have found that Meguiar’s rubbing compound makes a fine metal polish.
NU2theT
Last Name: Wendt
MTFCA Number: 32419
Post by NU2theT » Tue Jun 14, 2022 9:06 pm
I'm in with the Simichrome crowd, nothing else would touch my radiator shround.
Post by Allan » Tue Jun 14, 2022 10:54 pm
I use Autosol. It is a paste, like toothpaste. As such it is much more controllable than liquid polishes. It is cheaper in the larger cans.
Chris Instness
First Name: Christopher
Last Name: Instness
* REQUIRED* Type and Year of Model Ts owned: 1915 runabout, 1923 speedster
MTFCA Number: 52552
Post by Chris Instness » Tue Jun 14, 2022 10:58 pm
I also like Blue magic.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Jun 14, 2022 11:44 pm
I despise the new Brasso. It's not the Brasso we used when I was in the army. I agree that if your brass has been lacquered, you have to remove the lacquer with thinner before you polish. Like Frank, "I differentiate between removing tarnish versus polishing." I find CLR excellent for removing tarnish. But it will slowly attack brass over time, so don't let it soak long term.
I've tried most of the polishes recommended on the forum over the years, and I've settled on Mothers. It works well, is widely available, and costs a lot less than many of the other polishes. After polishing, I apply Nufinish hoping to delay the return of tarnish. I don't use lacquer. I don't like the look, and it's a pain to remove when you have to polish again.
If you spill any antifreeze on your brass, wipe it off immediately. It doesn't just make tarnished spots. It eats brass.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed Jun 15, 2022 1:46 am
Hi Neal,
How corroded are you talking about? If it's green or brown I use Zepp calcium, rust & lime remover. buy at Home Depot & Lowes. Small parts can be soaked, larger can be wiped with a soaked rag. Use gloves, eye protection & use in a well ventilated area. I have used it to clean brass firetruck parts for years. keep an eye on it it can turn brass dark if left to long. Works good for cleaning radiators, engine & head cooling passages also.
Craig.
catfishunter99
First Name: LORIEN
Last Name: HEGNER
Post by catfishunter99 » Wed Jun 15, 2022 7:54 am
I have also used the soaking method on extremely tarnished brass with good results. My chemical of choice is white vinegar. It does give brass a copper look until final polish and I may have read somewhere that repeated use might not be good. Only needed to do it once now just keep them shined up. Works for me! Your mileage may vary.
MTFCA Number: 51486
Post by TXGOAT2 » Wed Jun 15, 2022 8:19 am
"Brass" is an alloy, or a fairly narrow range of alloys. Using an acidic product may cause issues by reason of the acid eating one or more of the components of the alloy faster than others. I think this may explain why some types of cleaners, like soldering paste, can make brass turn copper-colored. I'd use any such cleaner sparingly and limit the time of exposure.
NealW
First Name: Neal
Last Name: Willford
MTFCA Number: 50256
Post by NealW » Wed Jun 15, 2022 10:08 am
Craig,
here are the door sill pieces as an example. The other brass pieces are dull and brownish looking, but not corroded as bad.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed Jun 15, 2022 10:48 am
Hi Neal,
Pat is correct about exposure. I used Zepp because it is stronger than vinegar. If you use vinegar try the commercial grade it's more like 30% -35%. Many of the polishes are acidic, I like to wash & wax after polishing.
Craig.
SurfCityGene
First Name: Gene
Last Name: Carrothers
MTFCA Number: 22905
MTFCI Number: 23068
Post by SurfCityGene » Thu Jun 16, 2022 1:14 am
Someone may have already posted about this brass cleaner. Brite Boy metal polish is one that I have found is by far the easiest to use on heavily tarnished brass. I got a gallon of it at the janitor supply store. It does not give the deep lustre that we get from the other polishes like Mothers Billet or Blue Lustre or Flitz and other high dollar ones But it works much easier on dark brass and then I do a second time with one of those which is very easy on the clean and bright brass. I
Brite Boy by Carroll Olde Tyme Products Garland Tx 800-527-5722 carrollco.com
1912 Torpedo Roadster
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Thu Jun 16, 2022 4:54 am
I have a 1912 hack with all the brass that goes with a 12. About 15 years ago I made a terrible mistake by taking it on our club tour that was based on Ocean Isle Beach in North Carolina. We toured for a week and about three days after I returned home I lifted the cover to find the worst case of brass corrosion I have ever seen. I was able to hand polish everything except the radiator back to the original luster. I could not make the radiator look good. With the help of a friend, I took the radiator off the car and we used his 12 inch buffer and buffing rouge. We had to be careful and kept our movements in sync but the result was we had the radiator back to a fine finish. In retrospect, I could have saved a lot of time and effort by buffing the large items like the lights and gas generator. Just a thought !
MTFCA Number: 51486
Post by TXGOAT2 » Thu Jun 16, 2022 7:45 am
SALT DESTROYS ALL!
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Thu Jun 16, 2022 8:02 am
Easiest way found for me to remove the very old brass tarnish is ketchup :)
Really works, slime it on, rub with a rag and the tarnish is gone. Clean well in soap and water rinse, then go on to polish using your favorite product.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Thu Jun 16, 2022 9:09 am
:lol: And I love ketchup on certain things...but wonder what it's doing to "our pipes"!!
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Thu Jun 16, 2022 9:28 am
Immerse in 50/50 Coke a Cola and Amonia for 24 hrs. Work down tough corrosion with appropriate grit wet emery paper, finishing up @ #1000 grit. Bench buff with high luster rouge (green). Finish up with Wenol hand polish. Take assembled brass apart for aggressive cleaning.
SR
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jun 16, 2022 11:58 am
This stuff... It's not polish. As the name suggests, it's a tarnish remover and it is also just about as "instant" as it gets! Awesome stuff!!! Follow up with polish of your choice.
https://www.amazon.com/Flitz-BC-01806-I ... NrPXRydWU=
Post by TRDxB2 » Thu Jun 16, 2022 1:54 pm
I would use it. But for those that don't read instructions: Instantly removes heavy tarnish without rubbing. ... Just spray & rinse. Product will continue to work on the surface until rinsed. You MUST rinse the surface with water after application and neutralize the formula to prevent and encroachment on the surface itself. After the surface is cleaned you must follow up with a polish or wax to keep it from quickly re-tarnishing.
The diluted ingredient is Urea Monohydro-Chloride
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jun 16, 2022 6:42 pm
Yes Frank. You should always read the directions. :)
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
MTFCA Number: 19790
Post by ABoer » Sun Jun 19, 2022 4:59 am
To polish our 1912 to do that it take's about a day .
And I don't like to do that often.
One time a model T-friend told me he has some thing to spray it on .
We both use that for four years ago now .After we drove in rain and snow several times, it looks still good.
Just a little darker as after polishing .
You can take it off with Aceton if needed
The spray is sold by: HG a Dutch company .
Toon
Darren J Wallace
First Name: Darren
Last Name: Wallace
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian Touring 1905 Queen model B
Post by Darren J Wallace » Thu Jun 30, 2022 10:10 am
Hi Jerry, I can’t seem to find anyone who actually has this stuff on the shelf in Canada or in NY state. It must have nasty stuff in it. Easy to buy online but nowhere on a store shelf (?)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Jun 30, 2022 10:43 am
... I can’t seem to find anyone who actually has this stuff on the shelf in Canada or in NY state.
I expect you can find CLR, also a fast tarnish remover. It too should be rinsed off before polishing, for the same reason.
Darren J Wallace
First Name: Darren
Last Name: Wallace
Post by Darren J Wallace » Thu Jun 30, 2022 11:07 am
Thanks Steve! I can get CLR anywhere! I didn’t know it worked on really tarnished brass!
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jun 30, 2022 11:55 am
Darren,
I have not seen it on the shelf here in Michigan either. I ordered a gallon of it on-line.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Thu Jun 30, 2022 11:57 am
Test a small spot first. My memory may be, (read as "is"), faulty, but I seem to recall CLR turning my brass purple.
jaybee47
First Name: jay
Last Name: bolante
* REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
MTFCA Number: 31221
Post by jaybee47 » Thu Jun 30, 2022 6:36 pm
I use Captain Richard's Bombs Away and am very satisfied. Inquire via a Google search.
andy2794
First Name: Andy
Last Name: Apjok
Post by andy2794 » Thu Sep 15, 2022 8:40 am
What is the best polish to use for brass after cleaning with Flitz?
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Thu Sep 15, 2022 10:45 am
Once you polish your parts, you can preserve the shine with Mohawk Lacquer spray. It goes on great and, unlike most protective sprays, dries crystal clear with no fogging. Try it and you will never use anything else. Jim Patrick
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Thu Sep 15, 2022 1:10 pm
Whenever I have used my buffing wheel for polishing, I have always used the red jeweler’s rouge buffing compound block. The red jeweler’s rouge is used specifically for softer precious metals such as gold, silver and brass for attaining the highest possible scratch free shine. The green block polishing compound, while a high luster compound, is more for harder surfaces such as chrome and stainless steel. Jim Patrick.
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Post by George Mills » Fri Sep 16, 2022 9:21 am
As a guy who 50 odd years ago learned that could sit on the floor with his can of Brasso and a rag and have unlimited hours to 'rub on/rub off' until the yellow metal shined like the sun...when I bought the 15 in 1995 the chore right off went to my then 12 y/o son! :lol:
I recently picked up a double barreled Bridgeport pump and someone said try FLITZ...which I had never heard of.
Spray on...holy cow where did the gunk go? THAT fast! Wash it off, hand dry it, then hit it with Flitz polish where it immediately comes up to a glow with a slightest hint of blue to make the item warm to the eye. Where were you 50 years ago Flitz? ....life would have been so much easier, but I'd probably have spent the same amount of time working my jump boots to make them look even more like Corfam :roll: :roll: :roll: .
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Fri Sep 16, 2022 12:25 pm
I used the spray Flitz, was done with both headlights and radiator in 20 minutes.
Rob
First Name: Rob
Last Name: Heyen
Post by Rob » Fri Sep 16, 2022 1:12 pm
Our 2022 OCF brass polishing assembly line:
https://www.dropbox.com/s/iqglpejyiq495 ... F.mov?dl=0
