How do you...
Posted: Tue Jun 14, 2022 9:15 pm
by NU2theT
connect this little bugger through the leather pieces into the lower hood ends. I do not have any tool small enough to flatten the little supplied rivet.
Any input would be great and Thanks in advance.
Re: How do you...
Posted: Tue Jun 14, 2022 9:40 pm
by Humblej
Support the rivet head on a buck, use a center punch to flair the rivet, then a ball peen hammer to form the mushroom.
Re: How do you...
Posted: Tue Jun 14, 2022 9:53 pm
by TRDxB2
The proper tool is a rivet clincher. It is designed to role the edges of the tube rivet over (used on Model T ignition switch rivets). You could try to use a some punches, one to spread the tube and the other to flatten - chance of success about 40%. Or just replace the tube rivet with a split rive (washer optional).
Re: How do you...
Posted: Tue Jun 14, 2022 10:09 pm
by MichaelPawelek
Note….You don’t rivet them on the way they come out of the package. They are folded where the rivet goes through 4 pieces.
Re: How do you...
Posted: Tue Jun 14, 2022 10:10 pm
by MichaelPawelek
This is the proper fold.
Re: How do you...
Posted: Thu Jun 16, 2022 5:43 pm
by NU2theT
Thanks for the pictures and that piece of paper work...I used to have that somewhere when I opened the package last year, per usual just getting to it now. I will try Langs ect for that rivet punch.
Re: How do you...
Posted: Thu Jun 16, 2022 8:47 pm
by Oldav8tor
I just applied a little silicone adhesive on both sides and clamped it in place with a small wood block on either side. Two years on the leather is holding great.
Re: How do you...
Posted: Thu Jun 16, 2022 10:19 pm
by OilyBill
An EXCELLENT source for rivets and the proper punches and tools to install them is "Hanson Rivet and Supply Co" of Pacoima, California. Their phone number is 818-485-0500. If you use the correct tools for the rivet you need to install, it will be done in 5 seconds, and will look perfect.
Or you can half-mule it, and look at those results for the next 40 years.
It's your choice.
