How to remove a Gross Jet?
Posted: Fri Jun 17, 2022 6:31 pm
by cwlittle
I would like to replace a Gross Jet with a Viton tip valve in a rebuilt carb I have. I have the new jet, but I can't figure out how to remove the Gross Jet. I can't get a small wrench on it. Is there a secret to removing these?
Re: How to remove a Gross Jet?
Posted: Fri Jun 17, 2022 6:41 pm
You dont mention which carb. They are all different.
I have worked with NH's. A small socket has worked so far.
Posted: Fri Jun 17, 2022 7:20 pm
by cwlittle
NH, sorry.
Posted: Fri Jun 17, 2022 8:31 pm
either a socket or nut driver (my preference). In some cases you may have to grind the "roundness" off of the face of the driver in order to present as much "oomph" on it as possible. If not, and the face is too blunt, you'll just round off what little hex is showing on the valve, and your day will have just gotten a lot worse.
Posted: Fri Jun 17, 2022 8:56 pm
I had a chepo small socket set that had the correct size socket in it and carefully made a turn or two on my bench grinder with the socket. Worked OK after that. The small socket sets usually have a nut driver handle in them. The small socket sets are usually 1/4 “ drive.
Posted: Sat Jun 18, 2022 9:27 am
by cwlittle
The flattened nut driver worked!
Thanks!
