COIL BOX
Topic author - Posts: 690
- Last Name: S
COIL BOX
How bad is this?
Wood is cracked and deteriorated. Car runs good for 5 seconds then skips and does not recover.
Asking for a friend.....
Last edited by Professor Fate on Fri Jun 24, 2022 9:53 pm, edited 2 times in total.
________________
**FATE**
PM me if you have any Indian Motocycle parts!
**FATE**
- MTFCA Number: 24868
Re: THE HORROR!
It's bad.
- First Name: Ed
- Last Name: Martin
Re: THE HORROR!
I have repaired worse.
Best though is to replace the wood with a good (used to be?) Fun Projects kit (if they are still available?).
- MTFCA Number: 28924
Re: THE HORROR!
No Brainer! Coil box is shot and needs rebuilding. No kidding.
Re: THE HORROR!
This all you should need. You want to reuse the the metal contacts top & bottom (the Top have left & rights). The porcelain insulators clean up well in a rust dissolver. Whenn you take the bottom off not how its wired and to which post. The bottom contact needs its rivets drilled out and riveted back in place using the pop rivets included in the set. 4 screws hold the back & just one on the bottom
- Last Name: Juhl
- MTFCA Number: 50297
- MTFCI Number: 24810
Re: THE HORROR!
I don't think the plastic replacement kits are currently available. Nonetheless, the wood in that box is shot and needs replacement.
- Last Name: S
Re: THE HORROR!
I've converted mine to plastic and that's fantastic!
- Attachments
- tumblr_mklnmjbktf1qj0r5qo2_250.gif (788.65 KiB) Viewed 2895 times
________________
**FATE**
**FATE**
- MTFCA Number: 52564
Re: THE HORROR!
I made my own out of a 1/2 inch thick cutting board, it was blue! All you need is a table saw and drill. You have a pattern.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: THE HORROR!
Snyder's is selling a copy of the Fun Projects kit - it will do the job !
- Last Name: S
Re: THE HORROR!
I like the cutting board idea. Its a "slice above the rest!"
Did you use a router for the grooves for the coil contacts?
________________
**FATE**
**FATE**
- First Name: Rainer
- Last Name: Hantsch
- * REQUIRED* Type and Year of Model Ts owned: Lizzy: Model T Touring 1916, brass & black
Re: THE HORROR!
I would use good Beech plywood. The more layers it has, the better. Instead of milling out grooves, you may also consider buying plywood in two thicknesses, One piece in overall size, and then glue thin stripes on it with water-resistant glue to thicken it up "between grooves". This way you also get the grooves without requiring a mill/router.Professor Fate wrote: ↑Wed Jun 22, 2022 12:26 amI like the cutting board idea. Its a "slice above the rest!"
After finishing the new boards, I would soak them in oil. This gives a beautiful look and makes them water-resistant.
In my Lizzy, I oiled the boards when I had to pull the engine and the entire coilbox was unmounted. Was a quick job with surprising good results.
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Re: THE HORROR!
That one sure was yucky!
If those kits are like/the Fun Projects kits, they are very, very nice.
Re: THE HORROR!
In any coil box rebuild it should be mentioned as it was to reuse the original contacts inside the coil box.
The original contacts are much better than what’s being made now and will retain their tension almost forever. That tension is important for good contact.
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
Re: THE HORROR!
Aww....comeon...
My '15 had a box like that and started fine for the longest time. It was a bit of a mule starting, but it started and ran...
Unless...
You washed the car....
Or...
You managed to get past the washed the car thing, and let the car sit in a really hot sun, and then it was a 6 legged push start.
Funny, went with a fun projects rebuild kit just for the heck of it and now the mule seems to have retired or gone out to permanent pasture...
With a T you just never know....
Unless...
Or...
- MTFCA Number: 51486
Re: THE HORROR!
Moisture will aggravate problems with deteriorated ignition systems. Add a little salt and you're really not good to go.
Re: THE HORROR!
Nothing so fancy as a router, just multiple passes on the table saw. I didn't have a dado blade setup at the time, but would have worked better.Professor Fate wrote: ↑Wed Jun 22, 2022 12:26 amI like the cutting board idea. Its a "slice above the rest!"
1920 Dodge touring
1920 Dodge touring
Re: THE HORROR!
Note this requirement
- Last Name: S
Re: THE HORROR!
My good friend says plastic coil box upgrade improved nothing except aesthetics. Still skipping like a little girl....
- Attachments
- 30681e48c955352938183a8e479c146f.gif (2.19 MiB) Viewed 2458 times
________________
**FATE**
**FATE**
- MTFCA Number: 14383
Re: THE HORROR! Coil Box
You can have multiple problems.
Did your friend look @ the condition of the timer & brush?
It appears the coils have been reworked already.
Re: THE HORROR!
Maybe your friend just didn't want to spend the extra and used that as an excuse. With the cover on, you can't see it and have to look real close around the terminals to even notice.Professor Fate wrote: ↑Wed Jun 22, 2022 6:28 pmMy good friend says plastic coil box upgrade improved nothing except aesthetics. Still skipping like a little girl....
1920 Dodge touring
1920 Dodge touring
- Last Name: S
Yes. New Ron Patterson coils. But it has a very crusty and very vintage wiring harness. He's going thru it now step by step. Timer is next target to eval i guess.
________________
**FATE**
**FATE**
The ignition system consists of a number of parts and assemblies. All of the parts and assemblies must be in good working order for the system to work properly and consistently deliver a good spark to each cylinder at the proper time, every time. The ignition system is somewhat like a chain. It will only function as well as the weakest link.
