1910 sidelamp brackets
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Jun 24, 2022 3:27 pm
Were the sidelamp brackets used in 1910 brass plated or painted black? Here's what I found when I bead blasted paint off the brackets on my 1910. Brass plating over steel. Im wondering if I should shine them up or repaint them. Don't know if these are original. I suspect not. For sure the black paint was applied when the car was restored from parts in the 80s.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: 1910 sielamp brackets
Post by ThreePedalTapDancer » Fri Jun 24, 2022 3:30 pm
Brass plated.
viewtopic.php?t=9047
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Re: 1910 sidelamp brackets
Post by Pat Branigan Wisc » Fri Jun 24, 2022 3:38 pm
Who knows what some one had done in the past. One of my 10s were plated and also the starting crank. Hope this helps?
RGould1910
Last Name: Gould
Post by RGould1910 » Fri Jun 24, 2022 5:40 pm
Thank you fellas!
