Tire Tube Size
Topic author - Posts: 6
- Last Name: Galbraith
Tire Tube Size
Hello All!
I'm brand new to the forum. This is my first post.
I have a 1925 Coupe that I inherited from my grandad. It has been in a barn for the last 20+ years and I'm working on getting it back in running condition.
First thing to address is the tires. I've recently ordered the tires and tubes, however, the tubes that were shipped to me are 440/550-21 instead of 440/450-21.
My question is, can I use these tubes in the 4.4/4.5-21 tires?
Thanks and looking forward to gaining some valuable knowledge on this forum.
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Re: Tire Tube Size
Never saw 440/550 before, but that just means the tube will fit a 440 up to 550, they stretch and baloon, so, yes a 440/550 tube will work fine in a 440/450-21 tire which you have.
- Last Name: House
- MTFCA Number: 115
Re: Tire Tube Size
Yes, those tubes will fit in, I hope, new tires. Welcome to the Forum and world of Model T s Dan ...You’ll have a lot of learning opportunities ahead of you on the way to enjoying sheer fun with that coupe. As examples: proper operation of split rims, ensuring you don’t have babbitt thrust washers in the rear end and the joys of lubrication. There’ll be helpful instructional manuals to buy and I’d recommend framing a lubrication chart you’ll get from your favorite vendor in your first order. Others will chime in to fill in the blanks
- Last Name: Branigan
- * REQUIRED* Type and Year of Model Ts owned: 1909 two1910, two1911, 1913 Tourings
- MTFCA Number: 52262
Re: Tire Tube Size
Be careful when removing not to destroy the old tubes! They are probably better than the new ones! They will hold air for years where the recent ones need filling quite often. The latest that sound to be very good are Blokey.
- Last Name: House
- MTFCA Number: 115
Re: Tire Tube Size
Blokey ... he meant Blockley tires
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Tire Tube Size
Here you go, Dan. A couple of links for anybody new to the Model T game:
https://dauntlessgeezer.com/DG80.html
https://dauntlessgeezer.com/DG79.html
Re: Tire Tube Size
Thanks for all of the replies. I found someone who would mount the tires and I should get them back today. I’ll post pics with the new “shoes”.
Looking forward to really getting into this!
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: Tire Tube Size
Hear Hear George,
It never fails to amaze me the number of people that think model T's where lubed for life at the factory.
Craig.
Craig.
