foot pedal on floor
Posted: Mon Jun 27, 2022 12:26 am
by bnold5000
There is a strange little foot pedal in the center of the floorboards just forward of the seat that is no longer hooked up to anything on my 1915 touring car. What was the purpose of the pedal?
Re: foot pedal on floor
Posted: Mon Jun 27, 2022 12:27 am
by bnold5000
Posted: Mon Jun 27, 2022 12:56 am
by Chris Instness
Most likely was connected to an accessory exhaust cutout.
Is there anything below the floorboard? Such as a switch or a lever? It could have been a starter switch if the car had a starter at sometime in the past. Or it could be a muffler cutout switch or a switch to an exhaust whistle. If you can show what is below the floorboard, it might be easier to figure out what it is for.
Posted: Mon Jun 27, 2022 12:52 pm
by KWTownsend
What does the business end look like?
Posted: Mon Jun 27, 2022 1:12 pm
If that pedal is a 'locking' pedal, with a small toothed notch and spring too), then an exhaust cutout was once installed. The locking is to keep the cutout open, until you hit the pedal and release the lock, before the cops catch up with you :lol: .
IMG_5005 - Copy.JPG (99.73 KiB) Viewed 2766 times
If the pedal is just plain hinge, that is for an exhaust whistle, as you press and hold for just the instant sound, and a typical spring mounted some where in the connections allows the release for stopping the sounds.
Posted: Mon Jun 27, 2022 2:08 pm
Early roadsters which featured a "Mother In Law" seat were often modified by young husbands such that a small pedal on the floorboard released a catch that allowed the Mother In Law seat to tip backward. Operating the device while underway would provide an immediate reduction in noise levels.
Posted: Mon Jun 27, 2022 6:07 pm
….allowed the Mother In Law seat to tip backward. Operating the device while underway would provide an immediate reduction in noise levels.
Now that’s a good one! Ejection seat 1909….way earlier than Bond, James Bond :lol:
Posted: Mon Jun 27, 2022 9:46 pm
I believe it's for the JATO.
Posted: Tue Jun 28, 2022 11:43 am
by bnold5000
i finally got a chance to check the pedal out in more detail. It has the tooth that locks it down and the spring……so it looks like i had an exhaust cutout at one time.
Posted: Tue Jun 28, 2022 11:44 am
by bnold5000
here is the underside
Posted: Tue Jun 28, 2022 12:34 pm
Take a look at the exhaust pipe towards the rear o see if you have something attached to it. May be that the spring from the pedal is gone
