Question about hardware for brass Rands windshield hinges
Posted: Tue Jul 05, 2022 6:01 pm
by Tbird
So I have a original brass Rands windshield with its hinges. I believe this was original because of the plate glass that was still in the frame and the windshield Rands tag. I noticed that the 4 screws that held the hinges to the top and bottom of the frame have bolt heads. I then noticed that the vendors sell round head slotted machine screws for the hinges. Another brass Rands windshield that I live looked at that has original hinges also have the bolt heads for the hardware. I might also add that the frames are the later style meaning the upper half is smaller than the bottom for use with the one piece dash. I’m working on a 12 with the two piece dash and want to use the correct hardware for the hinges. I will not be using the windshield frame with the unequal halves but one with equal halves. Can anyone verify if the bolt heads or the slotted round head is correct.
Mike Bird
Re: Question about hardware for brass Rands windshield hinges
Posted: Tue Jul 05, 2022 6:03 pm
by Tbird
Posted: Tue Jul 05, 2022 6:57 pm
by 1915ford
The bolts are correct for earlier in 1911. By 1912 the slot heads replaced them. All were brass or brass plated.
Posted: Tue Jul 05, 2022 7:03 pm
by Tbird
1915ford wrote: ↑Tue Jul 05, 2022 6:57 pm
Did the 10-11 windshields have unequal halves? I thought the earlier windshields had equal halves with the two piece dash… could be wrong, I’m just not sure.
Posted: Tue Jul 05, 2022 8:49 pm
by JTT3
My 09 has unequal halves as does the 10.
Posted: Tue Jul 05, 2022 9:48 pm
In my ignorance at the time I pieced together my 1912 van, I used brass dome nuts with short lengths of all-thread to make "bolts'. They look the part, so I'm not about to fret over them.
Posted: Tue Jul 05, 2022 10:01 pm
by Tbird
Allan wrote: ↑Tue Jul 05, 2022 9:48 pm
Allan does you can have two piece dash or single?
Is your windshield equal panes? I read that cars with fixed roof heights used equal panes with the two piece dash and later unequal halves with the one piece dash. I’m using a two piece dash with a windshield with equal halves. I just want to use the correct era hardware on the windshield, whether that be the round head slotted or the bolt heads.
Posted: Wed Jul 06, 2022 12:16 pm
by Rich Eagle
I see this add for a "Rands" windshield. It is a different hinge but it has hex bolts. That suggests to me that hex may have been used by Rands.
https://www.prewarcar.com/289452-brass- ... co-detroit
Other than that I have seen no evidence in other than round head slotted bolts in my limited experience. I doubt that few would argue about using round heads but some might disagree with hex heads.
This is just my take on the matter.
Posted: Wed Jul 06, 2022 8:19 pm
Mike, the dash on my van is one piece. I was fortunate to be able to make an exact copy of an original, right down to the unevely spaced screw holes for the brass edge trim. The windscreen has two same sized panes.
Posted: Thu Jul 07, 2022 9:52 am
by RGould1910
I have seen both even and uneven size windshield panes on either single or two piece firewalls. I gave up trying to figure out which was correct for my 1910 and 1912 and assumed either was correct.. I finally chose which style to use according to whether or not the center channels were in my line of vision.
On my 1910 (two piece firewall) a windshield with uneven size panes placed the center channels in the wrong place for me.
Posted: Thu Jul 07, 2022 12:17 pm
by ModelT46
my 1910 has a Rand windshield (oringal to the car) with even halfs. An original 1912 i once had, the bottom half was wider.
Posted: Thu Jul 07, 2022 12:26 pm
by Tbird
RGould1910 wrote: ↑Thu Jul 07, 2022 9:52 am
Richard,
What hardware on the hinges? Round head slotted or hex head bolts?
Posted: Sat Jul 09, 2022 1:14 am
by RGould1910
Brass plated bolts on the 1910, screws on the 1912. Both Rands windshields. Photo shows the 1912.
Posted: Mon Jul 11, 2022 8:47 am
by Pete Ratledge
I have a late 1911. ( Nov ). It has a Rands windshield. The bolts are Brass plated with square heads. I'm not sure that a Rands windshield even had screws with slots.
