Tappet question? Not a noise...
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 30, 2022 9:21 am
Are there any tappets available with an oversized foot (larger diameter) that will fit into a T block? Recall A friend tried A tappets, but i recall a lot of machine work in a space with not a lot of metal and never went any further. Thanks!
Moxie26
Last Name: Jablonski
MTFCA Number: 407
Re: Tappet question? Not a noise...
Post by Moxie26 » Sat Jul 30, 2022 10:00 am
Cam lobe contact is centered on the tappet , the diameter of the tappet would prevent the tappet from dislodge ... Wear would be at that location and also where the tappet meets the valve stem after clearance during run. Due to valve stem/tappet wear, clearance using flat feeler guage is moot. ..... Perhaps camshaft removal and tappet removal may need to be done to measure lobe lift and set your stem/tappet clearances.
Last Name: Tannehill
MTFCA Number: 49460
Post by JTT3 » Sat Jul 30, 2022 10:13 am
Yes the vendors have them up to 0.30 on the shaft if that’s what you’re are talking about, they are the adjustable type. I’m not sure about the non-adjustable. If you talking about the head I’ll ditto Moxie26
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 30, 2022 10:36 am
Thanks...not a noise question. Engineering query.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Jul 30, 2022 11:04 am
This is probably a high lift cam inquiry... check into the 292 Y block lifters...
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Sat Jul 30, 2022 11:08 am
I’m not sure exactly what you mean. If you mean enlarging the tappet holes… yes. They have two sized reamers and tappets to fit: 1/64” over and 1/32” over. They have 1/64” over adjustable tappets. I am posting a picture of 1/64” over reamer and a set of 1/64” over adjustable tappets. Available from Lang’s and Snyder’s. Pictures from Lang’s. Jim Patrick
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 30, 2022 11:26 am
Thank you Kevin. Have you tried installing them? The only reference I had found was for a gentleman who was rebuilding a "N". Also, have you tried zephyr springs? Saw an A that had that mod.
Moxie26
MTFCA Number: 407
Post by Moxie26 » Sat Jul 30, 2022 12:01 pm
Replacing the tappets alone will not give you high lift. ... ... Looking to install a hi-lift cam ? .... We have the Stipe 280 in our 26 Runabout, with standard Ford tappets and stainless steel valves set to Stipe settings....runs great 👍 after 20 years.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Jul 30, 2022 12:11 pm
Thank you Moxie for the reply. Working with a cam builder, trying to find a lifter with a larger foot, as Kevin noted, going for a higher lift. If going to the effort to increase the base circle of cam, a larger foot on the lifter will be beneficial. With a larger base circle, the ramp of the cam becomes less steep, and side load on the lifter is reduced and a higher lift can be achieved. Of course, there is only so much space in that area. All compromises.
MTFCA Number: 14383
Post by speedytinc » Sat Jul 30, 2022 12:17 pm
Stipe offered a super hi lift cam. They made lifters with a larger head.
I recall 292 lifter heads are no larger than a stock T. I will look in the lifter department & let you know if there is a difference.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Jul 31, 2022 2:46 am
The 292/Y block tappet foot is 1" diameter- pretty much the same as the aftermarket T adjustable tappets. Your cam guy should be able to find a profile that will work with the 1" follower diameter. John is correct, Bill Stipe dis make some large diameter tappets doe use with his "Laurel"
cams. AFAIK, those are no longer available.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Aug 06, 2022 10:13 am
Thank you Dan, I will reach out and see if Bill is still making the tappets.
