Horn Picture
Posted: Thu Aug 04, 2022 8:11 am
by CatGuy
Can someone post a picture of a stock horn as would be found on a 26-27 T? I don't have one and would like to find one.
Re: Horn Picture
Posted: Thu Aug 04, 2022 8:40 am
by Mopar_man
Re: Horn Picture
by JTT3
Re: Horn Picture
Posted: Thu Aug 04, 2022 8:43 am
by DanTreace
'26-'27 electric horn with the proper bracket to mount due to the coil box on the engine with the Improved Car
- 542587.jpg (64.27 KiB) Viewed 1844 times
Note: Bracket is busted away at spot common to fracture due to shaky motor!
- IMG_0610 (600x450).jpg (123 KiB) Viewed 1844 times
And easy to convert any late T elec horn to 26-27 just by changing the bracket.
Re: Horn Picture
Posted: Thu Aug 04, 2022 9:05 am
by CatGuy
Thanks all! Very helpful!
Re: Horn Picture
Posted: Thu Aug 04, 2022 9:19 am
by CatGuy
JTT3 wrote: ↑Thu Aug 04, 2022 8:40 am
Well Scott I’ll see if I have one. So last adventure ended with a cover over your T. Any updates?
I'm chipping away at it.....slowly.... I now have the right side wheels back on and should have the left rear one on tonight. I found a guy that could weld the studs on the hubs/drums. Looks like it's going to work. The guy (Birdhaven) replaced the rebuilt generator with a new 6V alternator. The amps gauge still won't show a charge. Tonight after I get the wheel on I plan to go through the wiring.....again and see what is wrong. When I get a helper I plan to test the battery with the car running and see what that brings. I'm gaining. The car is a keeper, and if I ever get a bigger house/garage I might get another T or TT.......
Re: Horn Picture
Posted: Thu Aug 04, 2022 9:37 am
by JTT3
Re: Horn Picture
Posted: Thu Aug 04, 2022 3:41 pm
by jiminbartow
Here are 3 pictures of the original Ford script goose horn that was on my 1926 coupe when I bought my T in 1970. Jim Patrick
