A couple of months ago, I installed (5) brand new 4.50-21 Goodyear tires on the 21” split rims of my 1926 coupe. I took a picture of one of the labels. While I think I know what the numbers 4.50-21 mean, I am not absolutely certain. I have no idea what the CCAE1 means. Jim Patrick
What do the tire numbers mean?
Topic author - Posts: 2202
- Last Name: Patrick
- MTFCA Number: 50126
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Re: What do the tire numbers mean?
Jim-
4.50" is the sidewall height.
21" is the rim diameter.
Twice the sidewall height + rim diameter = tire outside diameter:
(2xx 4.50) + 21 = 30"
CCAE1 is probably an inventory code.
Keith
Keith
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
- First Name: Adrian
- Last Name: Whiteman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Yep, manufacturers part number.CCAE1 is probably an inventory code.
Thank you. I was wrong. I thought the 4.50 was the width of the inflated tire. Jim Patrick
- Last Name: Mills
- MTFCA Number: 29497
- MTFCI Number: 10032
CCAE1 is a tire code for a 4.50x21 polyester ply tire black rated just over 850 lbs. capacity each...
CCAE2 is a tire code for a 4.50x21 polyester ply tire whitewall rated just over 850 lbs. capacity each....
