American Bosch front plate distributor information
Topic author - Posts: 1036
- First Name: bryant
- Last Name: shafer
- * REQUIRED* Type and Year of Model Ts owned: 1926 tudor
- MTFCA Number: 51736
Iam looking for any information related to the American Bosch front plate distributor. Parts books, installation information and the like.
Bryant
this is a type T448 that I have obtained. Any help is much appreciated.Bryant
- Attachments
- 2E3C158E-3F30-4263-A94E-49547A8D02D0.jpeg (50.63 KiB) Viewed 2370 times
Re: American Bosch front plate distributor information
Here's some
There are instruction for the American Bosch 600 which is a clip on with centrifugal advance - no the same
- Last Name: shafer
I did see some of those pages so I printed them. I was kinda wondering where the rest of the book is? I found a guy that can get some internal parts but looks like the cap will be a little tricky to find. Any one else mess with these?
- MTFCA Number: 14383
Because of the cap/parts issue, I run an early vw 009 cast iron dizzy. Early(56?) mechanical advance unit & disable the automatic advance. Parts can be bought.
- Last Name: shafer
dose that require a conversion shaft that Lang’s sells?speedytinc wrote: ↑Thu Aug 11, 2022 4:21 pmBecause of the cap/parts issue, I run an early vw 009 cast iron dizzy. Early(56?) mechanical advance unit & disable the automatic advance. Parts can be bought.
- MTFCA Number: 52564
Check Chaffin's online catalog. The make some of the replacement parts for them. http://www.chaffinsgarage.com/ Don't think they have any parts for the original distributor, just the other parts.
1920 Dodge touring
1920 Dodge touring
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
I have a friend with two of those distributors that he has been looking for parts for several years.
He was told that is the earliest Bosch distributor and it has been obsolete for 50 to 75 years.
The capacitor does not need to be in the distributor.
Some coil holders have a tab bent up with one hole in the center tapped for a screw.
That is for mounting a capacitor and it appears to work the same there as inside the distributor case.
Exactly what is inside that large lower case or the reason for it is still a mystery to him!
I have done it both ways. Add a coupled shaft or make a 1 piece long shaft to replace the vw shaft also.Bryant wrote: ↑Thu Aug 11, 2022 4:26 pmdose that require a conversion shaft that Lang’s sells?speedytinc wrote: ↑Thu Aug 11, 2022 4:21 pmBecause of the cap/parts issue, I run an early vw 009 cast iron dizzy. Early(56?) mechanical advance unit & disable the automatic advance. Parts can be bought.
- Last Name: shafer
The thing looks really simple. Could probably hide adapted parts to inside if needed. The cap will be the hurdle I think. I might have to get creative as I would like to get this thing to work but I do like the “newer”Bosch distributor to get started . I guess let the treasure hunt begin!
- Last Name: shafer
For anyone interested and wondered what was inside I disassembled the distributor earlier. The main shaft has a interesting centrifugal fly weight set up. Everything seems worthy. Thou not to hateful the main shaft I would consider having duplicated.
- First Name: Howard
- Last Name: Tomlinson
I have an original cast iron unit with the distributor. When I bought it the front plate had no bearing or bushing where the bottom of the distributor main shaft would be supported. Is this correct?
I also have one of the aluminum reproductions and it has a roller bearing at that spot.
Thanks,
Howard
Thanks,
Howard
- Last Name: shafer
Howard I also did not see any bushing in there. Iam thinking there is plenty of oil splashing around by the drive gear it’s well lubricated. Mine looked to be in good shape.Howard Tomlinson wrote: ↑Sun Aug 14, 2022 11:37 amI have an original cast iron unit with the distributor. When I bought it the front plate had no bearing or bushing where the bottom of the distributor main shaft would be supported. Is this correct?
Thanks,
Howard
Bryant
- Last Name: shafer
Iam guessing but is there an oil cup that goes here? Maybe one that has a oil wick inside to go to the shaft?
- MTFCA Number: 24868
Yes, that's for an oil cup. I don't recall if there's a wick or not, but it would make sense if there were one.
- Last Name: shafer
Bryant
Here is what the original oiler looks like. As for the bottom bearing, there is no bushing, but there is a lube hole running to the bottom of the bearing. Make sure it's cleaned out.
- Last Name: shafer
Bryant
- Last Name: Pharis
I have never run a washer under the cam nut (didn’t know I was supposed to). You will find that the reproduction cam nut drive tangs need to be relieved to make clearance for the driven gear teeth. Adding a washer under the cam nut will only make this gear mesh interference worse.
Gear lash is difficult to set up as it is the crank seal that decides the lateral position of the front plate. A little extra clearance is better than none
Forgot I had this
Picture from PDF
- Last Name: shafer
Kevin
Thanks for the info about the drive nut modification. I wasn’t sure about the washer until I saw the picture with one in line.
Frank
Thanks for the extra information on parts with numbers. I would love to find that AB coil somewhere.
Getting closer
Bryant
Frank
Getting closer
Bryant
There are two different American Bosch Coils shown in their ads.Bryant wrote: ↑Sun Mar 24, 2024 2:40 pmKevin
Frank
Getting closer
Bryant
This apparently was a very early one but some of it is shown in the same ad as the more conventional one (second picture) --
I'm using the red American Bosch coil shown. I replaced the coil with a new 6v (had to drill small hole in bottom of the steel holder to break the vacuum holding the old coil in place. The red coil has American Bosch embossed along the top. I purchased the tag but have used it --
Here's one on eBay like I modified https://www.ebay.com/itm/115710603891?i ... R6ri0Z7OYw --
This is more like what I used https://www.ebay.com/itm/275925767280?i ... R6zi0Z7OYw --
The universal one ttps://www.ebay.com/itm/292991097481?itmmeta=0 ... Vh5koYxAqp
- Last Name: Pharis
Found this little bugger laying on the workbench. Notice the relief cuts on the drive tangs
- Last Name: shafer
Frank
I actually have the 3rd one listed on eBay on a watch list. I always wonder if they will still work.
Kevin
Thanks this is exactly what I was thinking with the driven nut modification. It’s a wonder it doesn’t come this way.
Bryant
Kevin
Bryant
You don't need to wonder- just plan on replacing the coil - may need ask for the diameter of the unit
I wasn't sure if coil I bought was 6 or 12 volt or if it was any good. Lang's had a 6v coil at the time for about $12. It wasn't that hard to replace. Its oil filled so mounting upright is recommend - gel is more expensive.
Kevin,Kevin Pharis wrote: ↑Sun Mar 24, 2024 6:07 pmFound this little bugger laying on the workbench. Notice the relief cuts on the drive tangs
Are the reproduction cam nuts made too long?
- First Name: DAN
- Last Name: MCEACHERN
When installing these you need to be very careful that the drive gear is located against the shoulder on the cam shaft and that the nut is not preventing the gear from locating properly. The tangs should just drive the gear, not locate it on the cam. The marks on the drive tangs above were most likely made by the distributor gear hitting the tangs. if the cam gear hub is thicker than an original gear, the nut will sit out too far and create a problem.
- First Name: Andrew
- Last Name: Clary
- MTFCA Number: 24057
I just installed one on a new McEachern gear with no issues.
Andy
Andy
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
- MTFCA Number: 292
- MTFCI Number: 106
I just installed one here without a washer, didn't come with one. I also had no problem with the tangs, no need to file them down.
Take a look: https://youtu.be/WhMediNH1Rs
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
- Last Name: shafer
Frank are you suggesting putting a new coil in an old case?TRDxB2 wrote: ↑Sun Mar 24, 2024 7:05 pmYou don't need to wonder- just plan on replacing the coil - may need ask for the diameter of the unit
Bryant
- Last Name: shafer
Thanks DanDan McEachern wrote: ↑Mon Mar 25, 2024 2:49 amWhen installing these you need to be very careful that the drive gear is located against the shoulder on the cam shaft and that the nut is not preventing the gear from locating properly. The tangs should just drive the gear, not locate it on the cam. The marks on the drive tangs above were most likely made by the distributor gear hitting the tangs. if the cam gear hub is thicker than an original gear, the nut will sit out too far and create a problem.
I think I have it correct but will definitely verify the positions of the gears. I see you make these gears? Are they made different to compensate for anything? Pictures of yours would be great.
Bryant
- Last Name: shafer
Andy
Thanks I did not realize Dan had made these gears. Great info for anyone looking to do the switch.
Tim
Thanks for the video link. I like the green color of your engine.
Bryant
Tim
Bryant
- First Name: DAN
There is more than one manufacturer of the front plate gears, but AFAIK, I'm the only one making reverse rotation gears for use with replacement Jeep and Nissan distributors. The gears are not the issue- the drive tangs on the nut come very close to the outside diameter of the mating distributor gear and as I said earlier, if the drive nut, for any reason is too far out on the cam nose, those tangs can interfere with the driven gear on the distributor shaft. I believe that Chaffins is the source for the drive nut, but that is just a guess on my part. That would need to be confirmed with them. The washer shown above in the original literature would move the nut out slightly in this regard. I'm not sure what the purpose of that washer was, but use caution if you install one. From a functional standpoint, there is really no need for a washer under the nut- Ford did not use one so..........
- Last Name: Clary
Sorry I meant to say I used Dan’s timing gear and the distributor gear depth was good.
Andy
Andy
