Bolt size
Myxr6turbo
First Name: Shawn
Last Name: Barnard
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Bolt size
Post by Myxr6turbo » Mon Aug 15, 2022 12:22 am
Hey guys, can anyone tell me that the bolt size is for the 4 bolts that bolt the torque tube to the hogshead are please? 1926 Model T coupe.
Thanks,
First Name: Adrian
Last Name: Whiteman
* REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Re: Bolt size
Post by A Whiteman » Mon Aug 15, 2022 12:32 am
Hi Shawn, we have bolt charts available on the site: https://mtfca.com/phpBB3/app.php/gallery/album/195 which will give you most bolt (and nut) sizes.
The one you want is: https://mtfca.com/phpBB3/app.php/gallery/image/1501
and you are looking for a 3/8" UNF 13/16" long
First Name: Adrian
Last Name: Whiteman
Re: Bolt size
Post by A Whiteman » Mon Aug 15, 2022 12:35 am
RGould1910
Last Name: Gould
Re: Bolt size
Post by RGould1910 » Mon Aug 15, 2022 2:13 am
3/8 x 24 tpi, same as engine to pan bolts.
The holes in the pan are tapped for 24 tpi. Check it out
Re: Bolt size
Post by Wayne Sheldon » Mon Aug 15, 2022 2:35 am
The two bottom ones are shorter, threading directly into the pan. The two upper ones are a bit longer, going through the holes in the hogshead and then getting castle nuts and cotter pins (although a lot of people shortcut with lock washers?).
I don't recall the actual lengths (pretty easy to figure what fits best?).
Myxr6turbo
First Name: Shawn
Last Name: Barnard
Re: Bolt size
Post by Myxr6turbo » Mon Aug 15, 2022 5:23 am
Thanks everyone that really helped. I bagged and tagged everything but I can't find these ones. I'm sure they are somewhere safe.
