Which Key
Posted: Wed Aug 24, 2022 10:24 am
by Brian D
Trying to help out a new guy.
Probably any key may work, especially a 55, however he wants a matching key
No numbers on this key.
Anyone tell what number this maybe!
Re: Which Key
Posted: Wed Aug 24, 2022 10:29 am
by TXGOAT2
The later style switches have the key number stamped in the lock cylinder beside the key opening. The numbers are small.
Re: Which Key
Posted: Wed Aug 24, 2022 10:32 am
by RajoRacer
Does the switch plate have "Ford" in script under the headlight lever ? If not, it's most likely an aftermarket & likely a # 55 key if not stamped on the cylinder.
Re: Which Key
Posted: Wed Aug 24, 2022 11:06 am
by George Mills
Really hard to tell without the other keys to compare. (my keyboard is at the winter house)
Ford only had 4 tumbler notch (teeth) combos, the rest was done with the groove locations on the blade.
Here is a picture of a keyboard with a set of keys...maybe you can zoom up and see????
Re: Which Key
Posted: Wed Aug 24, 2022 11:49 am
by TRDxB2
Looks like MAc's/Ecklers took the time to photo ever key individually. #55 guesses appear to be correct
https://www.macsautoparts.com/catalogse ... %20t%20key
Re: Which Key
Posted: Wed Aug 24, 2022 1:12 pm
by Norman Kling
Even the ones you buy aftermarket do not always work. I have a key for my car and it happens that a friend has a car with the same key. He got one at either a swap meet or on line with the same number, but it didn't work. Finally found one that worked. The aftermarket keys are not always ground exactly right.
Re: Which Key
Posted: Wed Aug 24, 2022 2:11 pm
by Mark Gregush
Had a customer's car with replacement 55 tumbler and key. If you inserted the key all the way it would not work, if left about 1/8" out it was fine.
Re: Which Key
Posted: Wed Aug 24, 2022 3:13 pm
by Brian D
Sure looks like 55 as many said.
I'll get a 55 and try!.
Thank you all,
Brian
Re: Which Key
Posted: Wed Aug 24, 2022 3:31 pm
by TRDxB2
If a new key doesn't fit properly in a 100 year old pot metal lock - could it be the lock and not the key?
Re: Which Key
Posted: Wed Aug 24, 2022 4:04 pm
by RajoRacer
When you get a look at the switch assembly, let us know if it's Ford script under the light handle, please. Maybe even post a photo.
Some years ago, some of the repro black switch plate assemblies all used a #55 key and it could be removed in ALL positions !
Re: Which Key
Posted: Wed Aug 24, 2022 4:44 pm
by Ed Fuller
If there is no number or Ford script on the key or the ignition switch, then that key is for the reproduction ignition switches.
A #55 key may or may not work. The tooth profile is similar to a #55 but there are some distinct differences. It all depends on how worn out the cylinder and the key are.
Brian, I sent you an email through the forum. I can help you out with the key.
Re: Which Key
Posted: Fri Aug 26, 2022 7:28 pm
by J1MGOLDEN
The after marked switch keys and cylinders are cut like a #55 Ford key, but that groove is centered and not offset like the #55 Ford key, so they do not interchange.
Re: Which Key
Posted: Sun Aug 28, 2022 6:04 pm
by Original Smith
I have a NORS C.D. switch assembly, and it is exactly the same as the Ford issue, except there is no script under the headlight switch lever. Also, the back of the assembly is bare metal.
