Best Carb Soaking Solution?
Posted: Fri Aug 26, 2022 11:41 am
by schwabd1
I'm going to attempt to rebuild a couple NH carbs. Just about like everything else, I understand the carb cleaning solution isn't as good as it used to be. What are you guys using?
Re: Best Carb Soaking Solution?
Posted: Fri Aug 26, 2022 12:18 pm
by ThreePedalTapDancer
Most carb cleaners no longer clean like they used to. I use lacquer thinner now. I use brake parts cleaner as a spray cleaner too.
Posted: Fri Aug 26, 2022 7:28 pm
by jiminbartow
I believe the active ingredient of the old carb cleaners was Xylene. You can get xylene by the quart or gallon at Lowe’s to soak your carb in if you choose. Jim Patrick
Posted: Fri Aug 26, 2022 8:16 pm
by TWrenn
FWIW...a new guy to the hobby that I have been helping, I had him soak his NH in a can of lacquer thinner overnight. The car started right up and ran great. I did this on another one years ago and same results. So much for all this drilling, pipe cleaner reaming etc. This stuff works! JMHO
Posted: Fri Aug 26, 2022 8:22 pm
And this goes without saying but be sure to blow out as best you can the small passages with air. If you have a mall stiff wire you can use that too to run in the small holes.
I used mineral spirits to soak the carb in and later used lacquer thinner. It seemed to do a good job. I used what I had already in the shop.
Posted: Fri Aug 26, 2022 9:18 pm
by jiminbartow
When blowing out the ports with air, or cleaning them out with a spray cleaner, use eye protection. Sometimes the port can make a U-turn and point right back at you. Jim Patrick
