New owner on LI of TT looking for mentors
Topic author - Posts: 101
- First Name: Bob
- Last Name: Benner
- * REQUIRED* Type and Year of Model Ts owned: TT 1924, touring 22
- MTFCA Number: 52622
I just bought a 1924 model TT. I am looking for someone to come and walk me through the possibilities of this truck. I figure that experience will save me time and trouble. Any one out there? I live in East Setauket.
- First Name: Henry
- Last Name: Petrino
Re: New owner on LI of TT looking for mentors
I'd e happy to help, but I'm 3,000 miles away. Post a few photos and we can talk on the forum if that would be useful. What are you considering?
- MTFCA Number: 16175
- MTFCI Number: 14758
There are a few T guys on Long Island, but I don't know if any of them has a TT. I hope at least one or two will see your post and get in touch. Meanwhile, here's something that applies whether you have a TT or a T: http://dauntlessgeezer.com/DG80.html
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Ditto with what Henry said.
Mine was built January of 26.
- First Name: Thomas
- Last Name: Pilz
- * REQUIRED* Type and Year of Model Ts owned: 1921 roadster, 1923 roadster pickup
Hi Bob I'm in manorville I'm not a TT guy but I do know T's. I have a 21 roadster and a 23 roadster pickup that I've been through pretty well inside and out. There is lots of TT knowledge on the forum. What you got? Post some pictures if you can.
- First Name: Bob
- Last Name: Benner
I added a couple of pictures to my gallery
- Last Name: Hicks
- MTFCA Number: 32518
You have come to the right forum, there are guys here who can answer any question you have.
That is a beautiful TT, lots of potential! There were so many bodies built expressly for different purposes, have you decided how you plan to finish it, or drive it like it is?
From the 4th main forward the T and TT are the same. Find someone in a club near you and they can get her running just right, and check the front axle, no problem.
From the 4th main back the TT is longer and heavier duty than the T. Scroll type rear axle. Lower gearing. But if yougo to google and put in MTFCA followed by your question you will probably find someone else asked it and had it answered!
Welcome to this site, you will find many friendly and knowledgeable people here.
- Last Name: Hicks
In the picture you TT has a Ruckstell which is a two speed rear. Most consider this a good thing. Are you familiar with them?
- First Name: Bob
- Last Name: Benner
Just that it adds a two speed option.
- First Name: Henry
You're correct, the Ruckstell adds a second speed option. On a TT that means you have slow and slower. Of course we don't yet know if you have high or low ratio rear end gears, but TT's aren't known for excess speed.
In your original post you mentioned exploring the "possibilities" of your truck. There are virtually limitless possibilities. I think the place to start is to discuss what you would like to do with it. If you plan to use it on the road then we should probably talk about an auxiliary transmission with overdrive, auxiliary brakes, turn signals, brake lights, and other such features. If you're planning to use it on your own property as a utility/work vehicle the list will look much different.
It looks like a great start.
- Last Name: Hicks
Ruckstell is underdrive and 1:1, so it does not add any speed.
You probably need it if you have the 5:1 rear, especially if carrying a load or if driving in a hilly area.
I have a T with 7:1 rear and maximum speed of 15 mph. I am presently swapping the rear for one with a 5:1 ratio, it should run 25 -30. It will also have a Ruckstell.
As a previous poster said, you have many options with a TT, you just need to decide which way you want to go. If you plan to drive a lot on the road or keep up with tours, I recommend the 5:1 rear.
And, in my opinion, if you have a Ruckstell, you need axillary braking. Many will disagree, and I have been wrong before.
