T Snowmobile reduction axles
Steve King
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
Board Member Since: 2010
Post by Steve King » Fri Sep 30, 2022 12:07 pm
Has anyone ever seen these T snowmobile reduction axles? I would like to couple these units I have with my complete 26 Ruxstell to put my sled together. Trouble is I'm missing the pinions that attach to the axle taper and mesh with the hub gear. I have a similar setup on my my 31 Super Snowbird except the hub gear is internal rather than this T external.
Steve King
Last Name: King
Re: T Snowmobile reduction axles
Post by Steve King » Fri Sep 30, 2022 12:09 pm
Closer shot of the hub and drum
Steve King
Last Name: King
Post by Steve King » Fri Sep 30, 2022 12:13 pm
Axle bearing in unit looks bigger than standard? Not looking at the stub axle bearing but the bearing the actual axle is supported by.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Sep 30, 2022 1:39 pm
Very interesting. Does that bolt on to the axle housings? Or are the housings made that way?
More pictures please.
Who made that?
Steve King
Last Name: King
Post by Steve King » Fri Sep 30, 2022 5:23 pm
It clamps to the axle. I don't know who made them, but they are similar to my Arps Model A Super Snowbird kit, so I suspect Snowflyer or Arps
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Sat Oct 01, 2022 9:39 am
The unit you have is from a "Superpower Snowflyer". In about 1926 or 1927 Snowflyer came out with this unit which replaced the need for a Ruckstall. The model they produced prior to this was continued as a lower cost model and was called the "Snowflyer Regular". The Superpowers also had longer skis with higher risers and a special raised crossbar. Since the Superpowers sat higher giving them more clearance almost all of the idler axle parts are different. in 1928 Superpower geared hubs became available for the Model A and were sold until about 1930. They continued on for at least another year with a successor company but that is another story.
Steve King
Last Name: King
Post by Steve King » Sat Oct 01, 2022 12:49 pm
Thank you Glenn for the history on the unit. Note how it's clamped to the axle.
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Sat Oct 01, 2022 11:34 pm
On a Model T the rivets for the backing plate ends were driven out and the whole cast ends were removed leaving just the tubes to clamp to. On a Model A since the ends with the shock mounts and the housing itself are all one piece, the ends were cut away and the axle housings which are tapered were machined to the same diameter as the Model t axle tubes. There is no differences between the Snowflyer parts for a T or A. Glenn
rainer
First Name: Rainer
Last Name: Hantsch
* REQUIRED* Type and Year of Model Ts owned: Lizzy: Model T Touring 1916, brass & black
Post by rainer » Sun Oct 02, 2022 2:12 am
Just a question of interest...
This reduction axles actually reverse the rotation of drums. So the car would have one two reverse speeds and one frward speed.
How is this corrected?
Is the entire rear axle reversed, so the differential's big gear is on right side? That will reverse the rotation of half axles.
Steve King
Last Name: King
Post by Steve King » Sun Oct 02, 2022 4:55 pm
Model A Super Snowbird is different. It has an internal gear in the drum. This unit has an external gear. Here is a picture showing the square set screw to lock the position. The direction question is a good one.
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Sun Oct 02, 2022 10:00 pm
I Believe you could purchase the rear axle assembly from Snowflyer modified and complete with the carrier reversed and the oil fill hole in the correct position. If the buyer was doing the modification themselves they could simply flip the rearend upside down. The need to add oil is minimal as long as you have good seals. These units were only used for a few months a year. the castings with the hubs had provisions for re-mounting a leaf spring. If you have ever seen a Montgomery Ward Utility tractor conversion or a Sears Roebuck Thrifty Farmer tractor conversion (after 1934) both having external tooth bull gears, you will see that most rear axles are simply flipped over. Glenn
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Sun Oct 02, 2022 10:02 pm
The modified rear axle housings are also listed in the parts manual list. Glenn
Steve King
Last Name: King
Post by Steve King » Tue Oct 04, 2022 3:03 pm
Glenn, if you flip the axle over, wouldn't you loose maybe 6" ground clearance. The offset of the gear reduction gives 2.5 to 3" extra ground clearance on my Super Snowbird. If you flipped it over that would double.
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Tue Oct 04, 2022 10:07 pm
Steve. Flipping the axle over without the Snowflyer super hubs installed is the same as not flipping it because the Ford castings on the ends of the stock rear axle tubes have been removed. flipping the axle over is before the Superpower hubs are installed. The Snowflyer hubs are installed with the pinions (yours are missing) on top of the bull gear. The geared hubs do raise the rear of the Snowflyer but that is why the risers on the skis are higher that the regular risers. Not just to keep things level but to keep the float in the carb level. Glenn
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Tue Oct 04, 2022 10:11 pm
Steve. Are you planning on building a Snowflyer Superpower? Do you have the front ski assembly, the track and the idler axle assembly? Glenn
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Thu Oct 06, 2022 1:44 am
I biulding one based on TT
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Thu Oct 06, 2022 9:04 am
Bob. What brand are you using on your TT, Snowmobile, Snowflyer or Snowbird? Glenn
Steve King
Last Name: King
Post by Steve King » Thu Oct 06, 2022 4:07 pm
Glenn, I have the complete 8" wide tracks for the single idler and I have choice of all metal ski or wood metal combination. I have the buggy style springs and could chose to use a 26/27 large drum car Ruxstell or a TT Ruxstell I have. I could use a TT cab I have or a Kelsey touring body I have been saving.
Steve King
Last Name: King
Post by Steve King » Thu Oct 06, 2022 4:10 pm
This is my 31 Super Snowbird I finished in 2 years.
TractorGlenn
First Name: Glenn
Last Name: Heim
Post by TractorGlenn » Fri Oct 07, 2022 6:28 am
Steve. Sounds like you have a mixture of parts. Which brand are you trying to put together? Any of the four major brands would just use the truck rear end for a TT. A Ruckstell is not needed but of course would be desired. The geared Snowflyer hubs were only sold for T rear ends and later Model A's. The buggy springs and wood top skis sound like Snowmobile. Are the tracks also Snowmobile? What brand are the metal skis? If you have any parts you need identified post some photos. Glenn
