Bending Bendix washers
Topic author - Posts: 395
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Concerning bendix spring bolt washers. Does it matter where the tab that bends down rests? Should it touch the outer surface of the bendix spring or should it be down in "the gap" and the end of the spring
“The trouble with retirement is that you never get a day off.” – Abe Lemons.
- MTFCA Number: 14383
Re: Bending Bendix washers
The lower tab locks into the spring eye gap. It does matter.
To be clear, its the pre bent tab that goes in the gap. The tab you bend rests against the lock bolt face.
- First Name: Tom
Thanks. Is it in the gap enough as is or do you have to bend it into the gap a little more?
- MTFCA Number: 24868
It just needs to be in the gap enough so that the washer can't rotate and allow the bolt to back out.tom_strickling wrote: ↑Fri Sep 30, 2022 7:02 pmThanks. Is it in the gap enough as is or do you have to bend it into the gap a little more?
- First Name: Tom
Got it Thanks agian.
