Bending Bendix washers
Posted: Fri Sep 30, 2022 6:53 pm
by tom_strickling
Concerning bendix spring bolt washers. Does it matter where the tab that bends down rests? Should it touch the outer surface of the bendix spring or should it be down in "the gap" and the end of the spring
Re: Bending Bendix washers
Posted: Fri Sep 30, 2022 6:57 pm
by speedytinc
The lower tab locks into the spring eye gap. It does matter.
To be clear, its the pre bent tab that goes in the gap. The tab you bend rests against the lock bolt face.
Posted: Fri Sep 30, 2022 7:02 pm
by tom_strickling
Thanks. Is it in the gap enough as is or do you have to bend it into the gap a little more?
Posted: Fri Sep 30, 2022 7:26 pm
by Jerry VanOoteghem
It just needs to be in the gap enough so that the washer can't rotate and allow the bolt to back out.
Posted: Fri Sep 30, 2022 7:50 pm
by tom_strickling
Got it Thanks agian.
