Operating Centerdoor Windows
Topic author - Posts: 457
- First Name: Austin
- Last Name: Farmer
I have seen pictures of Centerdoor T's with the side window down. We have a 1920 Centerdoor, with a strap that hangs off the base of the window. How do you operate the windows?
The future of our hobby does not depend as much on youth, but on the future of internal combustion.
- MTFCA Number: 1219
Re: Operating Centerdoor Windows
They are similar to these TT straps:
http://www.mtfca.com/discus/messages/11 ... 1287772854
Maybe this is more help. I don't have a Centerdoor.
http://www.mtfca.com/discus/messages/82 ... 1546222046
- MTFCA Number: 14972
- MTFCI Number: 15411
We have a '19 - you need to pull up on the strap (carefully) to get the window & base off the small ledge holding the window up in place then simply pull inboard a smidgen & lower the glass. I believe the door window has or should have a couple holes in different spots for adjustment - just the door windows on our car, the rest are up or down.
- First Name: Stephen
- Last Name: Heatherly
I have a 1919 centerdoor as well. Only the door windows have the holes in the straps to adjust the windows.
Stephen
Stephen
- Last Name: Farmer
Thank you. So the way I understand it is the strap holds the bottom of the window inside the door. The window frame has a tab on the inside that hooks up with a hole on the strap that holds the window. Did I get it?
