26/27 cowl lacing
Posted: Sun Oct 09, 2022 12:54 pm
by elliott1936
I'm about to install the cowl lacing on my 27 model T cowl ,and was wondering which way the brass rivets would be installed. The rivets are two prongs that go through the lacing. Are they installed from the outside or the inside of the cowl?
Re: 26/27 cowl lacing
Posted: Sun Oct 09, 2022 1:54 pm
by DanTreace
Installed like band lining, split rivet into the lacing, head inside the cowl….best done with gas tank out, that’s how the factory done it :)
Posted: Sun Oct 09, 2022 4:03 pm
by George N Lake Ozark
When I did mine the gas tank was in. Previous restorer used pop rivets. I took the rivets and filed the sides down so the rivet sat in the groove better
Posted: Sun Oct 09, 2022 11:34 pm
by jiminbartow
They are installed from the inside. The two prongs are spread and curved into and embedded into the lacing. You will need a friend on the inside holding the rivet head tight against the inside of the cowl while you spread the prongs. This is one job you cannot do alone. Jim Patrick
Posted: Mon Oct 10, 2022 1:23 pm
by elliott1936
Thanks for the information. I will have a helper when I do this job. My son is helping me get my number 28 speedster back on the road with a new body style. Tom
Posted: Mon Oct 10, 2022 4:01 pm
by fordt
Wow, just now putting my gas tank in the dash and happened to see this! THANKS! I’ll put this on first!
Posted: Mon Oct 10, 2022 7:01 pm
by Allan
With the tank out, the rivets can be installed tangs out in the webbing as the factory fitted it, BUT, the two lowest on the sides will need different treatment because the rivets there cannot be inserted due to a double panel precluding same. Was the second panel fitted after the webbing? Most restorers resort to pop rivets at this location.
