Missteps and misdiagnoses chasing a misfire
Posted: Tue Oct 11, 2022 11:45 am
I was following a thread here about rough running, sputtering, and backfires. Then it happened to me... Here is my tale. Hopefully someone will benefit from my missteps. (here is a Youtube video I made of the situation https://youtu.be/3zKL5BXE95w Or you can read below.)
My car was running well, and has been trouble-free through the summer. I’ve made a few driving videos, gone to some car shows: I’ve just been enjoying the car.
On my way home from a local car show a few days ago, the car started running very roughly. Sputtering and backfiring. Much worse when accelerating or climbing hills. So this car was out of commission until I got it repaired…
My first thought was that I was running out of gas. So I added a few liters…no improvement. My next thought was dirt in the fuel, or rust, from my old gas tank. Maybe the screen in the bowl was plugged-up. So I took the plug out of the bottom, and found that it was very clean – no sediment. Maybe there is rust or something plugging the fuel line? Not likely, since the screen was clear, but I disconnected the fuel line here, and found that fuel flowed un-restricted. So that wasn’t the problem.
Wishing I had a spare, working Carburetor (which I don’t) I convinced myself it must be an ignition problem, rather than a fuel problem. And I did NOT want to consider that it might be valve problems, I did a complete valve job on this car in the spring! So I used a screwdriver to ground to verify that I had strong spark at the top of each Spark Plug. There was; all four coils seemed to be working fine.
Now the good mechanics among you, (I do not count myself among your number) will notice that THIS is where I missed the opportunity to discover the true problem. REMEMBER THIS MOMENT, I’ll come back to it later.
Still not wanting to take the Carburetor apart, I continued my ignition trouble-shooting. I took the Timer off, and found it to be a bit oily inside. So I cleaned it all up and put it back on. The car was still running poorly. Next I swapped a good coil into each coil slot, one by one, and ran the car after each swap. No improvements.
Convinced that the problem was not ignition, I returned to the Carburetor. There must be some debris blocking a jet or passage… So I took the Carburetor off, and took it all apart. Pulled the float (looked good – not sinking) Pulled the float valve and seat, pulled the needle valve and main jet. All clean with no signs of trouble. Cleaned-out the passages, and put it all back together and re-installed it on the car. Started the car, and it still ran badly.
Reluctantly I considered valve problems. I REALLY didn’t want it to be valve problems. So I removed the spark plugs and checked the compression in each cylinder. It was fine. Relief – I guess; no valve problems. But I still hadn’t found the problem!
So I gave up, and went inside, and read some Model T Ford Club of America forum posts about similar problems. They listed all the things I had tried already. But I noticed one post, where the author described shorting each spark plug, one at a time, to see if the engine stuttered. If it DID NOT STUTTER, then that cylinder is the problem. I hadn’t tried that yet.
So next time I was in the garage, I started it up, and proceeded to short the spark plugs one by one. Sure enough, Cylinder 1 was dead. There was lots of spark at the top of the plug, but the cylinder wasn’t firing. Could it be as simple as a dead spark plug? Yep. That’s all it was. The spark plug, somehow, failed. It will not spark at all. It’s wet and black, but shows no other signs of trouble. I replaced it with another old plug I had that was working, and voila, misfire cured.
I took the car for a cold test drive (it was only 4 degrees) and pondered my mis-steps. When I was checking for spark at each cylinder, if ONLY I had also shorted each cylinder in turn, I could have solved this simple problem much sooner, with much less effort. But at least my Carburetor is all cleaned and inspected now, and my Timer is serviced. Live and learn.
