Too much wear on my new day timer?
Posted: Tue Oct 11, 2022 8:13 pm
by JohnSaylor
Car is running a bit rough. Replaced my old (extremely worn out) New Day with this brown Bakelite New Day that Dave Hiltz gave me in 2020. Don’t remember how much wear it had when I put it on, but this is what it looks like now. Is this an acceptable level of wear? I might try polish it up a bit with some emery cloth
Re: Too much wear on my new day timer?
Posted: Tue Oct 11, 2022 8:50 pm
by John kuehn
Absolutely that new day is OK. Clean it up a bit with Emory cloth and you should be OK. It’s not that worn to me. Others will have their opinion.
Posted: Tue Oct 11, 2022 9:01 pm
by Moxie26
With the engine running, take a screwdriver with a good insulated handle and short out each plug at the top terminal. If the engine speed decreases and you see Sparks at the plug the plug is good. If there's no change in engine speed when the plug is shorted, you have a defective spark plug causing your problem.
Posted: Tue Oct 11, 2022 9:31 pm
by Norman Kling
Have you checked the coils?
Posted: Tue Oct 11, 2022 10:10 pm
by JohnSaylor
Coils and plugs are next on my list… just wanted to make sure it wasn’t the timer
Posted: Tue Oct 11, 2022 11:25 pm
by Steve Jelf
The timer isn't terrible, but it is starting to develop divots adjacent to the contacts. I would remove, or at least reduce, those.
Posted: Wed Oct 12, 2022 8:45 am
by JohnSaylor
Steve Jeff, what did you use to cut the wood backing plate to the perfect diameter?
Posted: Wed Oct 12, 2022 9:26 am
by JohnSaylor
*Jelf, sorry!
Posted: Wed Oct 12, 2022 9:27 am
by TWrenn
If it's ok, I'll chime in here...but a good hole saw the proper size is all you need
Posted: Wed Oct 12, 2022 9:31 am
by John kuehn
I don’t know exactly what Steve J. used to cut the round plywood piece for the new day timer sand paper backing but if you measure the ID of the timer you can use a hole saw to cut a perfectly round piece out of a 3/4” piece of plywood.
You can get one at a hardware store for around $4-8.00. And you have a perfectly centered hole in it too.
Posted: Wed Oct 12, 2022 10:15 am
by Steve Jelf
...what did you use to cut the wood backing plate to the perfect diameter?
As the other guys said, a hole saw.
Posted: Wed Oct 12, 2022 9:17 pm
by JohnSaylor
Hole saw … didn’t have the right size myself but I’ll go to the store and grab one
