Removal of 1926 fuel cover on cowling
Posted: Wed Oct 12, 2022 11:37 am
by dacapt1948
How do you remove the cowling fuel cap hinged cover? 1926.
Re: Removal of 1926 fuel cover on cowling
Posted: Wed Oct 12, 2022 1:14 pm
by Humblej
Two screws on the hinge go thru the cowl and are held by two nuts. All are accessible with the gas door open.
Posted: Wed Oct 12, 2022 1:19 pm
by Mark Nunn
Accessible and removable are mutually exclusive, in my opinion. I could not get enough of a grip on screw heads to loosen them. Maybe soaking in Kroil will help.
Posted: Wed Oct 12, 2022 2:12 pm
by John.Zibell
Mark Nunn wrote: ↑Wed Oct 12, 2022 1:19 pm
Try 50/50 Acetone and ATF mix. Works better than commercial penetrating oils.
Posted: Wed Oct 12, 2022 7:47 pm
by dacapt1948
Thank you all
Posted: Thu Oct 13, 2022 9:26 am
by Ken Buhler
Never turn a screw or bolt if it has a nut. Always hold the head hard with a well fitting driver and turn the nut. If it is a screw only, tap it as you turn in to assist breaking it loose, then tap as you loosen it.
Posted: Fri Oct 14, 2022 11:17 am
by Petrah Phyre
John.Zibell wrote: ↑Wed Oct 12, 2022 2:12 pm
Using this formula, do you mix it up as you need? My thoughts are that the acetone would flash off if not kept in an air tight container.
Posted: Sat Oct 15, 2022 11:05 pm
by jab35
Sean: I've got some in a pump type oil can and after 5 years it smells good and works well. You do need a closed container/oil can to reduce acetone evaporation, but the pump can does this. jb
Posted: Sun Oct 16, 2022 9:05 am
by Petrah Phyre
jab35 wrote: ↑Sat Oct 15, 2022 11:05 pm
Thanks James. I do have couple gallons of Kroll, but, as you are well aware, a couple gallons won't last forever when working on old stuff.
