What is this?
Posted: Sat Oct 22, 2022 7:55 pm
by Randy Mock
I made a purchase today.
Some are T some not so much.
Any help is appreciated.
Probably for sale soon.
Re: What is this?
Posted: Sat Oct 22, 2022 8:33 pm
That's a Babbitt setting hammer underneath the gray gizmo - the white tubes appear to have Babbitt cutting tooling !
Re: What is this?
Posted: Sat Oct 22, 2022 8:54 pm
by Randy Mock
I will get everything out for a better picture tomorrow.
Re: What is this?
Posted: Sat Oct 22, 2022 9:51 pm
by JTT3
Re: What is this?
Posted: Sat Oct 22, 2022 10:33 pm
by Randy Mock
I’m hoping the gray gizmo is something rare.
It’s likely the profit off this job.
Re: What is this?
Posted: Sun Oct 23, 2022 1:16 am
by Chris Paulsen
The gray “gizmo” is the feed for line boring equipment. Not necessarily rare or valuable but a good item if it’s not worn out. I’d be interested if it’s available and in good condition.
Re: What is this?
Posted: Sun Oct 23, 2022 11:13 am
Those axles look like you might have a "wide track" model T. Quite rare.
Re: What is this?
Posted: Sun Oct 23, 2022 1:14 pm
by Dan McEachern
The grey gismo is the Feed mechanism for an Aamco Line boring bar. Given the other items in that box, you might have the other parts that go to it as well. Post more pics of your treasures.
The ribbed tool laying under the gear rack of the feed box is a KRW main bearing babbitt peening tool.
Re: What is this?
Posted: Sun Oct 23, 2022 6:46 pm
by Randy Mock
More unknown
Re: What is this?
Posted: Sun Oct 23, 2022 6:47 pm
by Randy Mock
I assume all babbitt related
Re: What is this?
Posted: Sun Oct 23, 2022 9:58 pm
W.A.G. - appear to be Model A related. There's a pouring jig, pouring blocks and a thrust cutter.
Re: What is this?
Posted: Sun Oct 23, 2022 10:47 pm
by Dave Sullivan
I'd say the (Grey gizmo) is part of a line bore outfit.. Dave in Bellingham, WA
Re: What is this?
Posted: Mon Oct 24, 2022 6:00 pm
by dobro1956
#2 is a rear main thrust facer. The size of shaft will determine if it is A or T. #5 are main bearing pouring blocks. A set of them is usually 6 blocks but 2 long ones and 1short one will do.
Re: What is this?
Posted: Tue Oct 25, 2022 2:02 pm
by Randy Mock
Thanks for the info
