Clutch Speed Lever Adjustment
Posted: Mon Oct 31, 2022 1:15 pm
When the engine was out, I found the clutch/speed lever was very worn and was collapsing. I found that a previous owner had done a poor job with a repair weld. I straightened the wear surface and welded a new 1/8" thick plate along the top as a new wear surface. One thing I noticed when I pulled it out and reinstalled the adjustment Clutch Lever Bolt runs very closely to one edge. I would suspect it should run closer to the center (see image).
It does not look bent or twisted. Everything else looks like it is aligned correctly. I am thinking about taking a heat wrench warming it up and bending it so the bolt runs more centered. See any issues with this?
