Exhaust manifold threads
Posted: Mon Oct 31, 2022 10:24 pm
by Bill Anziani
Looking for the size and thread count on late model exhaust manifolds. Also any sources for the appropiate die
Thanks in advance
Re: Exhaust manifold threads
Posted: Mon Oct 31, 2022 11:22 pm
by Pep C Strebeck
1-7/8 x 16 tpi.
Posted: Mon Oct 31, 2022 11:24 pm
by JTT3
Posted: Tue Nov 01, 2022 12:07 pm
Here's a die for $42.00. I bought one a while back. Pretty nice quality but took a while to arrive from China. I had to break my rule of not buying from Chinese sellers, which was hard pill for me to swallow.
https://www.ebay.com/itm/233249148019?h ... R4r19L6GYQ
Posted: Tue Nov 01, 2022 12:08 pm
The last time I saw one of the new exhaust manifolds it was the 25-27 style. If you want the earlier type it may have to be an original.
by ModelTWoods
A friend of mine, who also participates in this thread, had a manifold with unsalvageable threads that he was desperate to save. He took it to a machinist who cut off the damaged threaded end and then made a new end with more common coarse threads and welded the end to the manifold. Then the machinist made a new nut (from steel) with threads to match the new threads on the manifold. I'm sure he had a manifold worth its weight in gold by the time all was said and done, but with the nut screwed on, you can't tell its not original.
Posted: Tue Nov 01, 2022 12:13 pm
If you can deal with the welding aspect, a common pipe union could be adapted for connecting header pipe and manifold. Welding might be avoided by inserting a pipe nipple or short length of exhaust pipe in the manifold outlet and securing it with a bolt.
Posted: Tue Nov 01, 2022 3:12 pm
I bought a new one for my 21 Touring. Worked fine for me.
Posted: Tue Nov 01, 2022 11:22 pm
by Bill Anziani
Thank you to all that responded. I do greatly appreciate it
