Robert
My reply inferred and means, yes, your T will run less smoothly on 6v, when you are running smooth on magneto. Obviously your coils are set for best performance on MAG.
Occasionally I will forget to switch to MAG from BAT after starting and run down the road and wonder?
what's up, she ain't purring good, sluggish, oh geez....forgot to switch. Instant correction, just by going on MAG!
Years ago learned that first hand, you must have your coils tested/set on either ECCC, StroboSpark, or HCCC if you run on Ford's magneto. Nothing else!
Of course those trembler coils are very adaptable and using 6vDC or even 12vDC, if no flywheel magneto can give you decent performance. However, these coils were designed for AC current from the magneto.
Used to just 'ear' test for best buzz, look for 'bright spark' at the new points and run the T. Worked back then for what I thought was
OK....an operating old Ford, with original engine and trans.
Complained at one tour where coils were being gratis set on a HCCT. Complained my T had weak magneto, as when I slowed down to idle, or low speeds, needed to switch from MAG to the 6v BAT for the motor to run right.
Well, had them there coils adjusted right on the spot, same points, put the set back in the T just as I took out, nothing changed only now the coils were adjusted the right way on the right equipment.
Wow...instant smooth best running the old '24 ever had on MAG. Could idle on MAG, could even start on MAG which I tried and could not do before, always blaming weak magnets......nope, justly properly set coils was all my Ford needed.
