High Compression Heads and Bore Size
Posted: Thu Nov 17, 2022 12:07 am
by JBog
Can you use a high compression head if your bore size and pistons are not stock? For example, my pistons are .030, would a Z head have issues?
Re: High Compression Heads and Bore Size
Posted: Thu Nov 17, 2022 12:12 am
by Kerry
No issues with bore size, just piston height needs to be checked.
Posted: Thu Nov 17, 2022 12:24 am
There are inconsistencies with some Z heads. They need to be carefully matched to the cylinder block. Oversize pistons are not the worry. You just might have to do a little re-shaping of the combustion chamber at the interface with the gasket.
The Prus heads are a better choice in my opinion.
Posted: Thu Nov 17, 2022 11:15 am
by Tim D
I have been running a Z head for 20 years and my block is bored .080" over. with alum pistons. No problems.
Posted: Thu Nov 17, 2022 9:23 pm
by Tmooreheadf
The last Z head I used required some relief grinding on the interior edged on all 4 chambers to prevent piston interference on a .030 oversized bore. I tried a Prus head on another engine bored .030 over with no modification needed. Prus advertises .080 with no interference and that seems to be correct.
Posted: Thu Nov 17, 2022 10:12 pm
by JBog
Thanks, guys!
