Whoopsie-Daisy Carb Issues
Posted: Fri Apr 26, 2019 5:11 pm
I pulled the T out last weekend. Put some fresh gas in the empty tank, ran great. Next day after a few miles of driving it just did not have a lot of power and would lurch a bit. Figured there was some dirty gas from the Jerry Can. No big deal. Last night I pulled the Carb off and cleaned it, along with the filter screen.
Went out for a 8 block test drive. After three blocks it was lurching even worse, staling every time I slowed the engine down for a stop sign. I was able to restart or could pop the clutch to keep her going.
Got home, by keeping the throttle pulled down a bit. When I parked I found fuel absolutely pouring out of the bottom of the carb bowl! I lost the carb drain screw. Not sure how much fuel I lost yet. I walked the route, I could follow the fuel trail starting about 1/2 block from my house. Found the valve plug screw. It was at on the ground at the very last stop sign, 6 blocks in to the trip.
When I cleaned the carb, I found the T handled screw tool tight. As I recall, I have always put it on figure tight. So I put it back on finger tight. Guess it needs to be tool tight, or a piece of safety wire to ensure in NEVER comes loose again.
Could have ended poorly, if I had wanted to go for a long drive.
I was impressed, I could keep the carb mostly happy with such a major leak.
