Another look at the other side.
Posted: Fri Nov 18, 2022 9:11 am
by Dollisdad
Re: Another look at the other side.
Posted: Fri Nov 18, 2022 9:12 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:13 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:14 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:15 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:16 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:17 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:18 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:19 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:20 am
by Dollisdad
Posted: Fri Nov 18, 2022 9:52 am
The 10th picture from the top looks like its a new Canadian 16 Touring. The odd thing is the left running board looks it’s been hit or slightly bent. Or it may have come like that from the factory?? Maybe when it got shipped dissembled and was slightly bent when it was put together.
Posted: Fri Nov 18, 2022 10:18 am
by Kevin Pharis
Just like the palletized car a couple pics below, you can just make out the fork mounted headlights. These headlights along with the ”kinked” splash apron makes these cars late ‘15 doesn’t it…?
Posted: Fri Nov 18, 2022 10:35 am
That very well could be. And looking at the palletized T it could be the same car in the 10th photo after it was put together! The T bodies weren’t the most sturdy and it wouldn’t take much to bend the running boards when it was picked up!
Interesting photos!
Posted: Fri Nov 18, 2022 10:56 am
by Kevin Pharis
Good eye! I completely missed the bent running board. I was referring to the “kink” or flare at the rear of the splash apron
Posted: Fri Nov 18, 2022 6:19 pm
by Wayne Sheldon
Clearly Tom R has been surfing the Southern hemisphere! The fifth photo looks to be an Australian 1915, (maybe a Tarrant?) Most of the cars are right hand driven.
The eleventh photo is an incredibly nice model T custom tourer of probably Australian origin (also maybe Tarrant?). 15, 17, 21, 23, all have the larger sloping cowl Australian common standard bodies were noted for during the 1920s.
Photo number 24 is an incredible custom roadster with a great deal of British influence.
I would sure like to know what the large non-Ford is in the seventh photo by the "Motor Garage". Not showing the very front of the car may make it difficult to identify.
Number 30 is interesting. Clearly, there is a model T under that car, although it sure doesn't look much like one!
Posted: Fri Nov 18, 2022 6:31 pm
Guys, the bent running board is on the RIGHT side, as is the steering wheel. The brass trims on the fork mounted headlights and on the sidelights both point to a 10915 model.
Posted: Fri Nov 18, 2022 6:48 pm
I wonder if that Ford-Rolls might have 2 T engines mounted inline?
Posted: Fri Nov 18, 2022 7:26 pm
by Erik Johnson
The speedster in the fourth photo has a Chevy emblem on the radiator shell - or at least the outline of one.
Posted: Fri Nov 18, 2022 7:34 pm
by John E. Guitar
Posted: Sat Nov 19, 2022 10:05 am
Did anyone notice the original factory stripe on that 1926 touring?
Posted: Sat Nov 19, 2022 11:26 am
by George House
The only New and Improved touring (facing left) I saw looked like someone keyed it 😞
Posted: Sat Nov 19, 2022 4:12 pm
Appeared to be a scratched negative to me ?
Posted: Sat Nov 19, 2022 6:03 pm
If you look above the "keyed" scratch, you will see a pinstripe about 1.5" down from the top of the doors, which continues around the back of the car. By 1926 the Ford factory in Geelong, Victoria was up and running, making the improved Fords. Towards the end, they were even making them two toned, trying to keep sales going. Those two toned cars had similar pinstriping. It may well be the same pinstripe as those used on those two toned cars, or perhaps a dealer enhancement.
Posted: Sun Nov 20, 2022 4:47 am
by Aussie16
Wonderful photos again. Thanks for sharing. Many of them I have looked at ,studied and filed before but you have also come up with some new Gems which I have not seen before. When I was younger, I used to catch trains from the Frankston railway station into the State capital, Melbourne city. Great to see a photo of the original old Frankston railway station.
Posted: Sun Nov 20, 2022 1:05 pm
by tdump
I wonder where the Coles furniture and Timber was located?
