Ammeter sourcing
Topic author - Posts: 45
- First Name: Matthew
- Last Name: Sinclair
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe
Ammeter sourcing
Hello, I can't seem to find the fun projects site anywhere and I can't find a 26-27 ammeter in stock anywhere let alone a 19-25 one that I would much prefer. Is there any reliable source of NOS ammeters or repops anymore?
Regards,
Matthew
Regards,
Matthew
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: Ammeter sourcing
Fun Projects sold out to Birdhaven a number of years ago - the large ammeter has never been reproduced. Someone is reproducing the small size that I read was much better than the imported model A version.
- First Name: Harry
- Last Name: Lillo
- * REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
- MTFCA Number: 13996
Steve, do you know who carries the higher quality smaller ammeters?
Harry Lillo
Harry Lillo
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
There is no such thing as a high quality small ammeter.
Only one company is the source of all of them and not all the dealers will even stock or sell them.
The large ones that John Regan made and was selling were top quality,
- Last Name: C
- MTFCA Number: 52098
Here is one source that has been referenced before:
www.westach.com/ammeters
Socialism is resentment disguised as compassion enforced by tyranny disguised as tolerance.
- First Name: Robert
- Last Name: Jablonski
- MTFCA Number: 407
www.westach.com 20-0-20 amp unit is advertised for Model A positive ground. Install in a 26-27 Model T, just reverse the wires as shown for positive ground to work on negative ground.
I have several of the smaller (26-27) and larger (19-25) tested repro small & original small & large. Various states of patina . Also the adapter plate to put the small ones in the 19-25 ignition switch if they are not made any more.M.Sinclair wrote: ↑Mon Nov 21, 2022 7:19 pmHello, I can't seem to find the fun projects site anywhere and I can't find a 26-27 ammeter in stock anywhere let alone a 19-25 one that I would much prefer. Is there any reliable source of NOS ammeters or repops anymore?
Regards,
Matthew
Most Farm Supply stores sell 2" amp gauges, Steiner tractors loo
I have found a large type ammeter that appears to be not functional, I do know it has spent it’s life in a toolbox completely dry. What would the feasibility be of either rebuilding it or having it rebuilt?
- MTFCA Number: 14383
Good looking large ammeters show up reasonable on Ebay frequently. There is a couple now. $40, 43, 49.
- MTFCA Number: 407
Pull up YouTube, enter Paul Shinn Model A ammeter, and you'll see his video for better contacts inside the ammeter greatly reduces probability of fire. The ammeter used in 26-27 is the same size diameter as used in the Model A. Loose contacts will generate heat. Cleaning then soldering inside contacts reduce heat.
Another large face showed up today $10 start.speedytinc wrote: ↑Tue Nov 22, 2022 11:10 amGood looking large ammeters show up reasonable on Ebay frequently. There is a couple now. $40, 43, 49.
I’ve got one it looks to be in alright condition I don’t know quite how to put a picture here but the dial is in good condition and the needle moves freely, I need to get it hooked up and tested but it looks promising
- MTFCA Number: 407
Matt: The video on YouTube will be helpful to ensure tight internal contacts.
Hooked it up and tested it it worked beautifully, media blasted the trim ring just to get the old paint and gunk off.
- MTFCA Number: 121
- MTFCI Number: 16310
I see the large and small ammeters on ebay often.
- MTFCA Number: 407
Hope you somewhat followed the YouTube video on securing good contact electrically inside the meter to prevent damage from heat and fire
I opened it up and checked the contacts, the resistance was normal for what I found but I touched them up anyways, when I tested it there was no feelable heat.
- MTFCA Number: 407
Matthew.. as long as you're satisfied with your results, it's your car , good luck.
- First Name: Adrian
- Last Name: Whiteman
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 Colonial Roadster, 1924 'Bullnose' Morris, 1925 'Bullnose' Morris, 1936 JD AR
Nicely done !
