Ruxtel and Rocky Mountains
Posted: Fri Nov 25, 2022 12:21 pm
by Don ellis
I’m sure there’s a way to run both but my shifter is hitting the rocky linkage from the brake pedal. Do I have to run the hand brake shifter or something?
Re: Ruxtel and Rocky Mountains
Posted: Fri Nov 25, 2022 12:24 pm
by Fire_chief
Try turning the shifter around so the spring is on the other side.
Posted: Fri Nov 25, 2022 12:33 pm
by speedytinc
Fire_chief wrote: ↑Fri Nov 25, 2022 12:24 pm
Your shifter is mounted backwards.
Posted: Fri Nov 25, 2022 12:36 pm
by Scott_Conger
Posted: Fri Nov 25, 2022 12:37 pm
by Don ellis
Sometimes you can’t see the forest for the trees, thanks
Posted: Sat Nov 26, 2022 2:06 pm
by Original Smith
One thing few folks know about Ruckstells, is when Eaton took over production from Hall Scott, they changed the design of the patent plate, to the clipped corner design which some people think is the 1926-7 design. Yes, it is, but it is really the Eaton design, and they made small drum models too with the clipped patent plate. I have one of those housings on my 1925.
