Hello,
How can we recognize a 1917-1922 frame ?
Regards
Frame 1917-1922 ?
Topic author - Posts: 9
- First Name: Stephane
- Last Name: Lezzier
- * REQUIRED* Type and Year of Model Ts owned: Touring US 1918
- MTFCA Number: 52245
- Board Member Since: 2022
- Last Name: van Ekeren
Re: Frame 1917-1922 ?
From 1919/22 will have holes for the battery carrier.
- MTFCA Number: 1219
First, it would have the forged running board brackets with the rods running between them (until '21). '19 and later would have holes for a starter switch. Previous to '19 it would be much the same as the '15 frame. It would have 2 holes each side of the frame top for the firewall (dash) brackets as well as two holes in the side of the frame for the latter firewall brackets. The top holes were eliminated but I'm not sure when. (edited)
More clues to come from others, I'm sure.
Some details here.
http://www.mtfca.com/discus/messages/70 ... 1498331647
Gavin Harris (Napier, NZ) provided this chart several years back. It should help.
http://www.mtfca.com/discus/messages/33 ... 356806.pdf
Some details here.
There is a lot of good information here if you have time to pour through it. It may answer some questions.
http://www.mtfca.com/discus/messages/33 ... 1366444998
http://www.mtfca.com/discus/messages/33 ... 1366355695
A bit too much for my slow brain.
On our Canadian sourced cars, the pressed steel running board supports were introduced on the 1922 models, superseding the forged type used earlier.
Thanks everybody
