Frame 1917-1922 ?
Posted: Mon Nov 28, 2022 3:25 pm
by Sanary22FT
Hello,
How can we recognize a 1917-1922 frame ?
Regards
Re: Frame 1917-1922 ?
Posted: Mon Nov 28, 2022 3:40 pm
by Kerry
From 1919/22 will have holes for the battery carrier.
Posted: Mon Nov 28, 2022 3:46 pm
by Rich Eagle
First, it would have the forged running board brackets with the rods running between them (until '21). '19 and later would have holes for a starter switch. Previous to '19 it would be much the same as the '15 frame. It would have 2 holes each side of the frame top for the firewall (dash) brackets as well as two holes in the side of the frame for the latter firewall brackets. The top holes were eliminated but I'm not sure when. (edited)
More clues to come from others, I'm sure.
Some details here.
http://www.mtfca.com/discus/messages/70 ... 1498331647
Gavin Harris (Napier, NZ) provided this chart several years back. It should help.
http://www.mtfca.com/discus/messages/33 ... 356806.pdf
Posted: Mon Nov 28, 2022 4:07 pm
by Rich Eagle
There is a lot of good information here if you have time to pour through it. It may answer some questions.
http://www.mtfca.com/discus/messages/33 ... 1366444998
http://www.mtfca.com/discus/messages/33 ... 1366355695
A bit too much for my slow brain.
Posted: Mon Nov 28, 2022 5:16 pm
by Allan
On our Canadian sourced cars, the pressed steel running board supports were introduced on the 1922 models, superseding the forged type used earlier.
Posted: Tue Nov 29, 2022 7:00 am
by Sanary22FT
Thanks everybody
