17-18 Coupelet mystery
Topic author - Posts: 310
- First Name: Eric
- Last Name: Macleod
- * REQUIRED* Type and Year of Model Ts owned: 13 Touring, 25 Touring, 27 Fordor, 27 Fordor, 26 Touring, '92 Stynoski, '06 Stynoski owner emeritus
- MTFCA Number: 50125
- MTFCI Number: 19464
Mark Eyre and I are a little perplexed. Last week he bought what appears to be a 17-18 Coupelet but some details are mysterious. Have the doors been changed? Is it a transitional car? The wood is highly intact and it appears largely original. Obviously some pictures are worth a thousand words so we're interested in hearing what you think.
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
Stynoski 2006, Nash, Franklin, Lincoln, Cadillac and Buick owner emeritus
1926 Touring
1927 Fordor (2)
1927 Touring
- First Name: Eric
Re: 17-18 Coupelet mystery
Here are a few more pictures.
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
- First Name: Eric
One more pair of photos
1913 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
1926 Touring
1927 Fordor (2)
1927 Touring
- MTFCA Number: 28924
Here’s an earlier post about Couplet changes
https://www.mtfca.com/discus/messages/4 ... 1388868942
- Last Name: Eyre
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
It has removable center posts. I will restore it eventually. I’m missing the side lamp brackets that have 4 countersunk screws that hold them to the body. I have seen it on two different Ford documents one calling it a Coupe and the other calling it a Couplet. Thoughts on which it is exactly? I can’t figure out how to post pictures I did it some time ago and couldn’t today so I asked Eric to post them.
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
I have a pair of those brackets. I have been using them to mount a pair of lights on an out building. If no one else comes up for a pair, I will let these go at a reasonable price.
Is that a battery access door in the floor of the rear compartment? The hinge does not look like any factory hinge I have seen. Perhaps the door is a modification to make the body fit a later frame at some stage.
"Coupe", "couplet", and "couplette" were all used in era advertising. Some people get rather persnickety about one or another word. I usually call the removeable pillar coupes a "couplet" myself, but for no particular reason.
Is this the one that was advertised in our classified section a short while ago? I never did follow the link to the photos. This looks like a pretty good start to a very rare model T!
I am not sure what your questions are? But it does appear that the gasoline tank was in the trunk originally. I know that some of them were. You should of course check with Russ Furstnow. He is the couplet expert. I "think" I heard he added a removeable pillar couplet to his lineup? (But I could be mistaken?) I believe it is a future restoration project?
I am not sure how many removeable pillar coupelets there are now? The count was less than ten a few years ago, although I am not sure if that included a couple known bodies or not. A few more have been found since, including a couple bodies only. Still very rare by model T standards.
This appears to be either late 1917 or 1918 style, with the flat roof? The "hump" top was only produced for a few months in mid 1917.
Great project regardless! I am positively green!
- Last Name: Eyre
It was on a 21 chassis. I have the original frame. It doesn’t have the holes for a carrier. The gentleman I purchased it from was going to build a rat rod out of it. I have the body and the frame and the title. It originally was an 18.
Thanks for saving the Coupe body from being a rat rod!! It’s to bad that some T’ and A’s wind up and get ruined to that fate. To each his own what they do with their car.
