17-18 Coupelet mystery
Posted: Sat Dec 03, 2022 7:26 pm
by EricMac
Re: 17-18 Coupelet mystery
Posted: Sat Dec 03, 2022 7:28 pm
by EricMac
Here are a few more pictures.
- Coupelet 4
- IMG_1037.jpg (30.98 KiB) Viewed 2607 times
- Coupelet 5
- IMG_1038.jpg (32.67 KiB) Viewed 2607 times
Posted: Sat Dec 03, 2022 7:29 pm
by EricMac
One more pair of photos
- Coupelet 8
- IMG_1036.jpg (17.99 KiB) Viewed 2607 times
- Coupelet 7
- IMG_1039.jpg (36 KiB) Viewed 2607 times
Posted: Sat Dec 03, 2022 7:33 pm
by John kuehn
Posted: Sat Dec 03, 2022 7:36 pm
by Model T Mark
It has removable center posts. I will restore it eventually. I’m missing the side lamp brackets that have 4 countersunk screws that hold them to the body. I have seen it on two different Ford documents one calling it a Coupe and the other calling it a Couplet. Thoughts on which it is exactly? I can’t figure out how to post pictures I did it some time ago and couldn’t today so I asked Eric to post them.
Posted: Sat Dec 03, 2022 8:21 pm
by ModelT46
I have a pair of those brackets. I have been using them to mount a pair of lights on an out building. If no one else comes up for a pair, I will let these go at a reasonable price.
Posted: Sat Dec 03, 2022 8:43 pm
by Allan
Is that a battery access door in the floor of the rear compartment? The hinge does not look like any factory hinge I have seen. Perhaps the door is a modification to make the body fit a later frame at some stage.
Posted: Sat Dec 03, 2022 8:45 pm
by Wayne Sheldon
"Coupe", "couplet", and "couplette" were all used in era advertising. Some people get rather persnickety about one or another word. I usually call the removeable pillar coupes a "couplet" myself, but for no particular reason.
Is this the one that was advertised in our classified section a short while ago? I never did follow the link to the photos. This looks like a pretty good start to a very rare model T!
I am not sure what your questions are? But it does appear that the gasoline tank was in the trunk originally. I know that some of them were. You should of course check with Russ Furstnow. He is the couplet expert. I "think" I heard he added a removeable pillar couplet to his lineup? (But I could be mistaken?) I believe it is a future restoration project?
I am not sure how many removeable pillar coupelets there are now? The count was less than ten a few years ago, although I am not sure if that included a couple known bodies or not. A few more have been found since, including a couple bodies only. Still very rare by model T standards.
This appears to be either late 1917 or 1918 style, with the flat roof? The "hump" top was only produced for a few months in mid 1917.
Great project regardless! I am positively green!
Posted: Sat Dec 03, 2022 8:47 pm
by Model T Mark
It was on a 21 chassis. I have the original frame. It doesn’t have the holes for a carrier. The gentleman I purchased it from was going to build a rat rod out of it. I have the body and the frame and the title. It originally was an 18.
Posted: Sun Dec 04, 2022 3:13 pm
by John kuehn
Thanks for saving the Coupe body from being a rat rod!! It’s to bad that some T’ and A’s wind up and get ruined to that fate. To each his own what they do with their car.
