Stainless tie wire
Posted: Tue Dec 27, 2022 1:00 pm
by Dennis_Brown
What gauge is the stainless steel tie wire used on engine and transmission bolts? I know it must be dead soft for twisting and bending but i am wondering on the gauge or diameter.
Re: Stainless tie wire
Posted: Tue Dec 27, 2022 1:11 pm
by Les Schubert
I don’t use Stainless Steel wire. Just ordinary steel wire.
Posted: Tue Dec 27, 2022 1:22 pm
by Humblej
I use .032 for smaller bolts, and .041 for larger.
Posted: Tue Dec 27, 2022 1:47 pm
by Oldav8tor
Same as Jeff - I also have a pair of aircraft safety wire twist pliers. If you're not likely to use them a lot, Harbor Freight makes a cheap pair for $10.
